Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 46 to 60 of 61
Thread: Which Way Do I Turn The Wheel WHen I Park?
  1. #46
    Registered User easy's Avatar
    Feb 2005
    Texas Hill Country
    Can there truly be purpose and direction to life if one's motorcycle wheel is not pointed in the right direction?
  2. #47
    redcat43 redcat43's Avatar
    Apr 2012
    SE Wisconsin
    I don't have a digital inclinometer like poster lkraus and was unable to compare the right/left lean figures, so now I'm confused. Maybe it would be best to simply gently lay my RT over onto the ground when I park. The RT is pretty easy to get back up anyway and that would eliminate the worry that the wind or some careless person might knock it over. But then I've still got the left/right decision to deal with and the problem of the fuel pouring out all over my parking place.
    Maybe I'll just continue leaving the bike in first gear while on the sidestand when I park, with the front wheel turned to the left and the ignition in the locked position. That seems to work OK for me so far.
    Oh yeah, another thing...I always mount or dismount from the right side. Learned that from a motor cop a long time ago...keeps you out of the traffic if you happen to park parallel to the roadway. Yeah, yeah, I know most of us generally back in to the curb perpendicular or diagonal to the road, but it's become a habit for me to get on or off from the right no matter how I park the bike.
    No matter where you go, there you are.
    2007 BMW R1200RT
  3. #48
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Quote Originally Posted by easy View Post
    can there truly be purpose and direction to life if one's motorcycle wheel is not pointed in the right direction?
    +1
    David Brick
    Santa Cruz CA
    2007 R1200R
  4. #49
    Apr 2008
    SW Ohio
    He should of ask which way should I or which way do you turn the wheel. As far as which way he turns it, left, right , center or random seem to cover it.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
  5. #50
    Dec 2007
    Reno, NV
    Cool
    Wow! This all seems rather, uhhhhh, retentive?
    What about, pointing it whichever way feels more stabile for that particular spot? Such has been my traditional primitive habit.
  6. #51
    Delaware.Dave
    Quote Originally Posted by Easy View Post
    Actually, to counter-steer, it must point in the wrong direction!
    For what it's worth, I turn my wheel to the right when there is an "R" in the month (This also ensures the steering stops wear evenly).
  7. #52
    Motorsickle Rider brisco's Avatar
    Oct 2010
    De Soto, KS
    Ooh. Something else to obsess over.
    Worn steering stops.
    Any suggestions on what type of lube should I use on those stops????
    Kansas. Eleven curves in three hundred eighteen miles...
    '09 R1200RT '73 R75/5
    N0PGH
    Iron Butt Assoc. #47865
  8. #53
    Northern Front Range, CO
    Quote Originally Posted by mneblett View Post
    I've noticed a couple folks mention this. Every R11/1150/12/K-bike I've owned will allow you to turn the ignition key to the locked position with the bars full left OR full right. I'm not aware of BMW doing this any differently on any individual models.
    funny, in all the BMWs i've owned (airheads, R1100S, K75s, K1100s, F800GS) I have never found a fork lock that allows locking when bars turned to the right! same is true on ay other branded bike.
    (edit- i got curious, so i checked it out. my R11 will lock to either side. thanks mark! still- I rarely use the steering lock, and still gonna lock to the left, as that one wants all the lean i can give it, and left turned goes that the best.)
    to the OP's question-
    most bikes prefer a left turn bar to park. its more stable, and only way the steering lock works. that is what we teach in the MSF BRC.
    HOWEVER, my F800GS generally prefers right turn, due to its high saddle height, and extreme left lean. this makes mounting and getting the bike to an upright position easier. my WAG is that this is the reason that they recommended the right turn park.
    Ride Safe, Ride Lots
  9. #54
    Themason 42906's Avatar
    Jan 2007
    Ridgecrest California
    My early K-100RS has the steering lock on the left side of the steering stem and there is no way to operate the steering lock if the forks are turned to the left. The left fork tube interferes with the key, making it completely impossible to lock the fork with the wheel turned to the left. It is always locked to the right.
    Experience is what you get when you don't get what you want.
  10. #55
    WOW - I had no Idea!
    Ok, so I have to admit, I had no idea how many replies I thought I would get to a simple question. I guess there is no right answer.
    A couple of things:
    1. On my bike you definitely can not lock the bike if the wheel is turned right.
    2. One I got used to the right it does seem easier to grab the brake since it is closer to you as you get on the bike if it is pointed right.
    3. I went back to the BMW Performance Center in SC and asked why they turn to the right and they said:
    "The reason we park the bikes with the wheel pointed to the right is for added balance and stability when mounting on and off the bike."
    Thanks for everyone's opinions! I love my bike and having the greatest fun learning since I did not grow up riding and none of this comes to me naturally. Parking and maneuvering at slow speeds right now are my biggest challenges. Please have pity on is newbies!
    Thanks!
    Jay
  11. #56
    Jul 2007
    THE BIG SKY
    Hey Jay, what kind of oil you planning to use?
    Enjoy your bike and your time on the forum.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  12. #57
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    When you begin to walk away from the bike, is it approperiate to take the first step with your right or left foot?
    Ken
    -Albert Eienstein
  13. #58
    Pismo Beach, CA
    we're not spose'd ta talk about politics on the boards... .. .
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
  14. #59
    Jan 2007
    Quote Originally Posted by Ken F View Post
    Ken
    Huh? Don't we all skip down the street when we leave our bikes?
  15. #60
    It's a way of life! oldnslow's Avatar
    Oct 2011
    Ash Grove, MO
    My scientific research showed the following:
    Using a spring scale attached to a length of rope and firmly attached to the frame of my K100, I measured a needed force of 35 pounds to pull the bike from its resting position on the side stand, causing it to fall to the ground on the opposite side of said stand, when handle bars were in the full lock left position.
    Again, repeating the test, but with the variable of the bars turned full lock right introduced, and the bike weighing approximately 3 1/2 pounds less due to fuel spilled and mirror missing from previous test, I found a needed force of 31 pounds to pull the said bike from its resting position on the side stand, causing it to fall to the ground on the opposite side of previously mentioned side stand. This shows a difference of 1/2 pound of force needed to tip the bike over. (taking into account the 3 1/2 pounds of missing fuel and body part. NOT taking into account the laws of physics as they apply to a body at rest with pressure exerted against said body which is at rest on a fulcrum, ie; the bike's wheels.)
    This should put an end to the discussion, as science has spoken.
    Now please excuse me, I am about to start my test that will explore the different degrees of engine protection offered by various weights and brands of motor oil during sustained static full throttle operation of same said bike. I fear however, my results of said test may be inconclusive, due to test subject only being able to complete one administration of said full throttle static test.
    .(I have wayyyy too much time on my hands!)
    Mike Davis
    "Old n Slow" It's a way of life!
    1985 K100RT
    1998 R1100RT
