Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 61
Thread: Which Way Do I Turn The Wheel WHen I Park?
  1. #16
    Nov 2011
    Central Ohio
    I usually park with the wheel pointed left. This seems to put more weight on the sidestand and feels more stable on level ground. Turning the bars to the right tends to make the bike stand more upright and makes me worry it will get knocked or blown over to the right.
    At least, that's what I thought until a couple minutes ago...
    I dug out my digital inclinometer, zeroed it to my generally flat garage floor and placed it on my gas cap to measure the actual angle from vertical on the sidestand.
    Wheel to left: 10.9??
    Wheel to right: 12.3??
    So, turning to the RIGHT should actually be more stable on level ground.
    Sadly, not the first time my perception of reality has been flawed.
    Larry
  2. #17
    Nov 2005
    Fairfax, VA
    FWIW, I have a simpler system which doesn't require any one-side-fits-all rules:
    If I have any doubt about stability on the side stand when I park, I try both ways. I then leave the bike with the wheel turned in the most stable direction for the particular surface/incline where I've chosen to park. If neither way make me comfortable, I find another place to park.
    Mark Neblett
    Fairfax, VA
    #32806
  3. #18
    Aug 2005
    SoCal
    It all depends what you ride.
    I ride R1200C cruiser, and it already leans too far to the left, and moving my wheels to the ride makes it easy to get on, plus it appears to be in a more stable position. I worry that because it leans sooo much to the left, that it might even fall if someone was to push it from right to left position.
    When leaving unattended, I have no choice except to point the front wheel to the left to LOCK the bike.
  4. #19
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by Montauk View Post
    I've noticed a couple folks mention this. Every R11/1150/12/K-bike I've owned will allow you to turn the ignition key to the locked position with the bars full left OR full right. I'm not aware of BMW doing this any differently on any individual models.
    Mark Neblett
    Fairfax, VA
    #32806
  5. #20
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by lkraus View Post
    Maybe, maybe not. Turning the wheel to the left places the tire point of contact with the ground further out in front of the bike than when turned to the right. The longer wheelbase and different geometry relative to the side stand and rear wheel contact points can add stability in some situations, potentially canceling out the 2-3 degree greater lean.
    Mark Neblett
    Fairfax, VA
    #32806
  6. #21
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I disagree because stability is not wholly determined by lean angle. Stability is also determined by how far apart the bike's supports are.
    With the front wheel turned left (toward the sidestand), the front tire contact patch moves to the right, so the three points that support the machine (front tire contact patch, rear tire contact patch, sidestand foot) are further apart than if the front tire is turned right. With the tire pointed right, the front contact patch moves left, towards the sidestand. The triangle of support becomes narrower, and the bike is less stable side-to-side compared to a bike resting on a wider triangle.
    In the real world, I think the answer depends on the interaction of several factors (levelness of ground, lean angle, whether the front wheel is turned right or left), not just just on front wheel direction.
    David Brick
    Santa Cruz CA
    2007 R1200R
  7. #22
    Enjoy The Ride saddleman's Avatar
    Apr 2009
    Huntersville N.C.
    I prefer the straight look so that is where I leave it. If it falls one way or the other after I dismount it oh well. I do turn it to the left when I am refueling.
    Dave
    2004 Black LT
    2000 Canyon Red LT
  8. #23
    Jul 2007
    THE BIG SKY
    I think Jay, the OP, is learning another valuable bit of information. Ask for the time on this forum and someone will tell you how to build a steam powered wristwatch.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  9. #24
    RK Ryder
    London, Ontario
    I've never thought about which way to turn the front wheel when parked! Now I'm confused.
    My ignorance was bliss. Now I have something else to worry about doing wrong.
    Paul
    Knights of the Roundel #333
  10. #25
    It's a way of life! oldnslow's Avatar
    Oct 2011
    Ash Grove, MO
    Quote Originally Posted by AKBeemer View Post
    Distilled water or tap water for the steam?
    What type of fuel should I use to heat the water?
    And what grade and type of oil for the internal gears?
    Mike Davis
    "Old n Slow" It's a way of life!
    1985 K100RT
    1998 R1100RT
  11. #26
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    Why?
    Always with my K75. It smokes like a destroyer dodging a torpedo if you leave it on the side stand. On my R1200R, it is mostly habit, plus it is easier to get in the bags and put the cover on.
    1988 K75 Low Seat
    2009 R1200R Roadster
  12. #27
    Sep 2006
    It depends which side of the Mississippi I am parked on
    Steve Henson
  13. #28
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    Quote Originally Posted by dbrick View Post
    I've not tried it, but I think I'd have to disagree with you.
    I'm unable to measure from my sidestand to the frontwheel at this time as the rear portion of the frame is pointed toward heaven as the poor thing sits on it's centerstand & front wheel.
    However, I would almost bet you that the contact patch is further away from the centerstand turned to the right than to the left.
    If you have time, try measuring....
    Ken
    -Albert Eienstein
  14. #29
    Apr 2012
    Gilbert, AZ
    I agree, you guys are way over-thinking this...
    2004 R1150RT
    BMW MOA 181289
  15. #30
    Santa Cruz CA
    Quote Originally Posted by Ken F View Post
    Ken
    Ken,
    I just went into the garage and put the bike on the sidestand. Using a yardstick on the ground: with the front forks turned left, the distance from the edge of the front contact patch to the edge of the side stand foot was 31 1/4". With the forks turned right, the distance was 29 1/2". That says to me that the stand/front wheel side of the support triangle is a bit wider with the forks turned left. I think (other things equal) that a wider support triangle is more stable than a narrower one.
    Admittedly, I wasn't measuring to the center of the contact patch. But I don't think doing so would affect the result.
    David Brick
    Santa Cruz CA
    2007 R1200R
