Results 1 to 4 of 4
Thread: clutch problem.
    Aug 2012
    South Carolina
    Cool clutch problem.
    Hello, I have a clutch situation on a 2007 K1200GT. 20k miles and the clutch is engaging when you start the MC in gear. One dealer says I need a new clutch and another informed me it could be a toque problem.
    Does anyone have/had a problem with this or any information.
    Kevin- South Carolina
    You stupid, fix it! r11rs94's Avatar
    Tiverton, RI
    Sorry your first post had to be about a clutch problem. I cannot help with that, but welcome to the club. I'm sure that someone that can help will jump in soon. Good luck.
    The thing about traveling is, you never want it to end and you can't wait to get home.
    I answer to Roy, Chief, or Sarg.
    04 R-1150-RT current bike. 94 R-1100-RS74,383, Sold, 78 R-80/7, K.I.A by a D.U.I
    www.OceanStateBMWriders.com
    #13338 PGlaves's Avatar
    It sounds like a problem wiwth the hydraulics to me. If there is air in the system or if there is a problem with either the master or slave cylinders it won't move the clutch far enough to fully release. I'd check that first.
    Aug 2012
    South Carolina
    Ok so last night I decided to take the reservoir cap on the clutch off...( it was full to the top.. Blue in color) and as I eased it in I did get airbubbles ....then I tied the handle to the grip and let it sit overnight...
    OK now the questions.
    Should I leave the handle in and put the cover back on! or let it out, then put the cover back on ...
    also ...in bleeding the brakes .....On top top( right side of MC where the cable/line runs into).. it is just an allen screw and not a bleedable ( grease zerk like fitting)..I was told to bleed it from the bottom but I didn't find a fitting to open.
    Kevin-
