Results 1 to 11 of 11
Thread: HID not always coming on
    Registered User jnrugg's Avatar
    Sep 2007
    Danielson, Ct.
    I bought the HID kit for my 02 RT from 1Off Motorsports just before they closed shop.
    So I can't go to them for help.
    Wired up ok and when it turns on it is great, even in the daylight.
    The issue is the light does not always come on when I turn on the ignition.
    If I turn it on and off several times it will come one but I don't want to wear out the ignition switch.
    I have it wired in as they say, but is there a better way or is this a problem with the ballast or the unit? If so then I will just go back to the regular bulb, if not then I would like to fix it.
    Thanks,
    May 2007
    Raleigh, NC
    I had the same problem with my high beam (same company) on my R12RT. It seemed to solve itself. Don't know why, but it solved itself. Maybe the bulb "burnt in"?
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    Braintree, MA
    Double check the connectors for a tight fit, they're finicky.
    -Tom (KA1TOX)
    Dec 2008
    Bremerton WA
    Does your kit have a cast ballast case,a black plastic ignitor housing and a clear cased :ice cube relay"????
    My kit was sold by Bikemaster but I believe the kits are all made in the same Chinese factory.
    In my opinion the relay may be hanging up. My system was acting up since day one when I installed it on my RT. I ended up running dedicated 12+ and ground leads right to the battery terminals and it still would act up from time to time. It would light up during key on cycle but when you cranked the engine the HID would go out (like it was supposed to with a working load relief relay on the bike). After engine start sometimes I would bwe running dark. One time it happened I reached into the faring and gave the relay a good smack,the light came on and she has been working well ever since(looking right now for wood to knock on)
    Check your connectors and smack your relay around a bit and see what happens...
    Perry
    Perry Brokaw
    97 R 850 R :sold
    98 R1100RTL:
    98 R1100GS:
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    I bought the same kit from 1offmotorsports and had a problem with one of the connectors not fitting properly. Had to take it apart and refit, but it works fine now. Does anyone know where to get replacement bulbs?
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    User
    Oct 2005
    Modesto CA
    I had the same thing happen twice in the 100,000+ miles I have had HID on my bike. Just turned off the ignition and then turned it back on. No problem. Same ballast unit for all those miles but I am on my third bulb. I just get replacements from DDM or some ebay seller. They all look the same to me.
    Berry Griffin
    Modesto CA
    Braintree, MA
    Quote Originally Posted by serazin View Post
    Yep, ebay for bulbs.
    -Tom (KA1TOX)
    Relay
    Ditto what Brokaw said. Find a good sealed Bosch brand relay. It drove me crazy until I figured out that the relay was the problem and not the ballast.
    Sep 2007
    Danielson, Ct.
    Quote Originally Posted by wrenchbender View Post
    A relay sealed from the weather?
    Isn't it under the seat?
    Do you have a part number?
    When it works it works, that is when the load relief relay kicks in the light comes back on. There are 2 black boxes, one is the ballast and the other the controller I guess. When I get the bike back from service I will check the connectors again.
    Braintree, MA
    The relay should plug in somewhere on the HID harness. There are a lot of crappy relays out there. Good ones aren't expensive.
    -Tom (KA1TOX)
    Sep 2007
    Danielson, Ct.
    Quote Originally Posted by tommcgee View Post
    I found this when snooping the internet, it all depends on what you search for.
    http://store.ijdmtoy.com/HID-Convers...adapter_04.htm
    If connectors for HID are standardized then this looks like it will work, esp. for $8.
    Opinions?
