Results 1 to 10 of 10
Thread: Any one try sea foam?
    A friend of mine tryed some of this stuff in his old Triumph and thought it made a difference cleaning out the carbs. My 03 F650 sat for 6 years and got a total of 400 miles riden in that time. Now it runs OK since I just bought it but I find that when its hot, and I go to start it up, alot of the times it will give me a pop back up through the carb just befor it starts up. And thats with a new iridium NGK in place. Any thoughts?
    Registered User robertklee's Avatar
    Mar 2006
    Tennessee
    I put it in everything I got. Motorcycle. Mower. Tractor. Gas. Diesel. Especially if it's going to be sitting for a while-like all winter and you don't drain it. My motorcycle mechanic says no other brand compares to it.
    Don't have a clue why/if it would affect your motor that way.
    RKL
    "Leave the gun. Take the cannoli."
    Quote Originally Posted by robertklee View Post
    Thats good to hear. I think I wasnt clear in my post. I just bought the BMW 2 weeks ago and was thinking maybe the sea foam might help the fuel delivery since it does the pop at start up time to time. The bike has 3200 miles on it but like I said, The woman that owned it since 06 only put 400 miles on it in those 6 years prior to my purchase of the bike.
    Iv read some good things about sea foam but knowing it will work well at cleaning these fuel injected bikes would make me feel better buying the stuff.
    Registered User QSrider's Avatar
    Feb 2009
    Salt Lake City, UT
    Thumbs up
    A while ago I bought a 01 Dakar that had been sitting for 3 or 4 years. Gas as well as old really black oil had been left in the entire time. When I bought it, it wouldn't start. I blamed the old fuel...
    I took it home, drained the fuel and cold old oil. Replaced with fresh and added Seafoam to both by Seafoam can directions. The bike started and ran like crap for 50 miles. I kept going to 100 miles (non stop). Got home and drained and replace the 100 miles old oil (it was dark already) and topped the tank with fresh fuel and filled the engine with fresh oil.
    I never did anything else and the bike has ran great since.
    I didn't know about Seafoam before using it on the Dakar. I had read about it on this and other forums. Watched YouTube videos...
    I decided I had not much to loose since the bike was not running. I gave it a try and it made me a believer.
    It was an easy and cheap fix to a big problem.
    I would do it if I were you. Can't really hurt.
    Good luck,
    Eric.
    01 F650GS Dakar
    03 R1150RT
    Thanks for that experiance. Seems there is nothing but good stories out there on sea foam. Im going to try it out asap.
    Apr 2012
    Marion County, Illinois
    I had a Harley that fouled plugs constantly. Nothing worked. Then someone suggested sea foam. Problem solved. I run it in everything, primarily as a stabilizer during winter.
    2011 R1200GS
    2004 R1150R Rockster (traded)
    May 2006
    Northern New Jersey
    I bought a '78 Honda several months ago. Previous owner only put 100 miles on it in the past two years and it sat unused for a year. When I started it, it hesitated badly and I would only get half throttle out of it before it bogged down. About 35 MPH top speed.
    Seafoam into the gas tank with fresh gas, a few ounces into freshly changed oil, and I used the Seafoam with the spray attachment directly into the carbs. After that treatment and 1 tank of gas, the problem was solved 95%. Further use in the gas tank cleared it up completely. Problem fixed, no tank disassembly, no carb disassembly, no engine work.
    Rally Rat bigdelta's Avatar
    Aug 2006
    Punta Gorda,Fla
    I think there was a thread on Seafoam not so long ago.
    I have used it for many years in everything from my lawnmower to bikes and cars.I use half a can prior to oil changes in my cars.
    Jul 2007
    THE BIG SKY
    Xtriggerman, the search function is your buddy. Here are just a few of the threads about Seafoam.
    Best to run the stuff just before changing the oil. Maybe a few hundered miles or so. If it works it can put bad stuff in the oil.
    http://forums.bmwmoa.org/showthread....hlight=seafoam
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Gez, I guess it has been mentioned a time or two here! thanks for the read, i'll be sure to search next time.
    Today I tryed some in a 07 China 200 dirt bike I have. The bike ran real bad with breaking up but would start n idle fine. I cleaned the carb and jets twice with small effect. I dumped a fair amount into the tank and man it ran much worse! back fireing and very ruff up at revs. I just kept guning it out to top revs as best as it would go and after about 3 minutes, the bike cleared up and began running smooth. The bike runs like new now! Hard to believe but it does work. The F650 will get a measured dose next.
    Thanks to all who commented.
