Results 1 to 5 of 5
Thread: Sprocket Change
    Registered User rtravelbee's Avatar
    Oct 2010
    Lower Michigan
    Sprocket Change
    I just changed the countershaft sprocket on my 2010 F650GS. I added a tooth. The only place I could find an 18 tooth sprocket was Tourtech. I have put about 500 miles on since changing it, and I have dropped about 500 rpm. When I added the Tourtech saddle bags, I gave up several miles per gallon. Their boxes hang out on the side like mini walls. I am pleased to report interstate mileage has increased 4 miles a gallon. I have not noticed any struggle to take off from a stop. Now if I could find a 38 tooth rear sprocket.........
    Randy
    Aug 2008
    North Carolina
    Wow ... I'm impressed.
    Thanks for sharing the results of the experiment!
    Registered User andreb's Avatar
    Jun 2009
    De Forest, WI
    I Did It On My F800GS
    I changed my front sprocket from the standard 16 to a 17 tooth unit. My mileage went up by about 5 mpg, and the engine is much smoother. It is now in a more relaxed rpm portion. It hurts a bit a slow speeds, but the trade off is worth it, especially if one does a lot of highway miles.
    Andre Boening
    2010 F800GS and 2012 K1600GT
    Braintree, MA
    You are trading for lower revs at highway speed when you go up a tooth in the front. The price is reduced torque. Personally, I don't like this trade off.
    Mpg figures are suspect, depends where the odo gets the feed. Use gps rather than the bike gauges to calculate mpg.
    -Tom (KA1TOX)
    Oct 2010
    Lower Michigan
    sprocket
    My mileage increase is off my GPS, not the odometer.
    Randy
