Results 1 to 3 of 3
Thread: R1200GS fitting replacement foot pegs
    Jul 2012
    Ladera Ranch, CA
    Just about to replace my foot pegs on my R1200GS Rallye 2012.
    I cannot get the bolt out on the gear change side.
    Do I just need to jiggle it a bit more or does the gear change leaver need to come off?
    Mar 2011
    socal
    Mark and remove gear selector, when replacing you may want to rotate it counter clockwise a notch to match up with lower pegs
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    On some bikes (my '05 for example) the shaft is marked and the slot in the lever is supposed to line up with the mark. There is supposedly a warning that says you shouldn't mis-align the lever. I don't know why.
    Maybe it's like the warning about not running the saddle with the front in the high position and the rear in the low position...
