Page 4 of 4 FirstFirst ... 2 3 4
Results 46 to 55 of 55
Thread: Camheads use oil? 2012 R1200RT
  1. #46
    Nov 2005
    Fairfax, VA
    I wonder how much oil use varies with environmental factors?
    My '12 RT is approaching the 6K oil change. Up to last week, it had used ~1/2 qt. since the 600 mi. check. One afternoon last week, I was 2-up in a long, hot DC traffic jam. Oil temp went up to ~3/4 of the display, but never reached the top of the range -- but I could certainly smell hot oil. By the time we got home (and after allowing the engine to drain on the sidestand, then putting it on the centerstand) the level had dropped to the bottom of the red ring in the sight glass. I put in .45L to bring it back to the top of the red ring. It stayed there through this weekend's 650 mi camping trip to the southern VA end of the Blue Ridge Parkway, during which the temps were on the 60's-70's.
    Mark Neblett
    Fairfax, VA
    #32806
  2. #47
    Talking
    I changed the oil and filter at 190 miles. At 932 I did it again. I put in 4 quarts. it was half way up.
    Its now at 2600 and almost to the red line. I bought a real 'BMW filter today. When it gets below the red line or hits 3000 miles, I change it. I added 4 oz once.
    Using dino 20 50.
    I will fill to the top red line this time hoping to make 3ooo miles with out adding.
    This weekend I drove it like I stole it. What a frikkin blast !
    159 miles of 3rd and 4th gear. I hit the rev limiter a few times.
    Edit, I broke it in by the book except the oil changes.
    David
  3. #48
    Sep 2006
    Quote Originally Posted by DROOT153718 View Post
    David
    6K oil change intervals are really OK and the norm ya know? Your dollar and your peace of mind...but not necessary...just sayin'.
    Steve Henson
  4. #49
    Feb 2010
    Westchester, N.Y.
    6000 miles is the norm, but do you ever notice how much smoother and quieter your engine runs with nice fresh clean oil in it? And it seems like reading these threads, writers always say they burn more, or add oil the closer they get to that 6000 mark.
    I change it at 3000. The 45 bucks and 20 minutes of labor is worth it to me. Your results may vary.
  5. #50
    Sep 2006
    You old Airhead /'57 Buick owners are a hard lot to change your ways...
    I think the smoothness is a perception personally...but not my bike nor money...so I don't try to change anyones ways.
    Steve Henson
  6. #51
    Norm Norms 427's Avatar
    Nov 2011
    Spokane, WA
    Here's a good read on oil change intervals from edmunds.com, it's titled, "Stop Changing Your Oil, Breaking the 3,000-Mile Habit":
    http://www.edmunds.com/car-care/stop...762858&msite=w
    Now: '12 R1200RT Midnight Blue Metallic / '11 Ural Patrol 2WD ridden to Alaska / '09 KLR 650 / '05 HD Heritage Softail / '08 Harley Sportster 1200C / '85 Yamaha VMax bought new. I wasn't ready to say goodbye: www.shaunlunt.typepad.com
  7. #52
    Dave Nicholls 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    2010 RT Oil Usage
    I too used a great deal of oil when new. The mechanic said this was normal and to stop using synthetic oil for the first 20 to 30,000 kms. I did that and the oil consumption has stoped completely. I now have nearly 60,000kms on the bike and no oil used between changes..
    Dave Nicholls
    Teulon Manitoba - Canada
    2010 1200RT
  8. #53
    Feb 2010
    Westchester, N.Y.
    You old Airhead /'57 Buick owners are a hard lot to change your ways....
    Hey guilty as charged! Like Popeye says "I ams what I ams"!
  9. #54
    Registered User wvpc's Avatar
    Dec 2009
    Ypsilanti, Michigan
    update to post #4 and #44
    I just rode home from Seattle where I stayed with mineral oil and changed oil & filter last. The RT burned 300cc in the 3500 miles home so it appears my oil usage rate has improved. I am now at 12,500 miles.
    This flatlander finally had a chance to run up and down some mountain ranges which helped to vary the engine load much more than the mostly flat and straight roads in SE MI and aided the breaking in of the motor.
    12 R1200 RT
    83 R100 RT
  10. #55
    Update
    in post 47
    Last oil change 2700 miles
    I put in 4 qts 4 oz. Its over full and been that way for 1300 miles.
    Bad news, I overfilled it.
    Good news it seems to have totally stopped burning oil at 4,000 miles.
    My 1100 was burning 1/2 qt (L) every 800 to 1000 miles. 130,000 miles
    I pulled it apart for rebuild. The cylinders still had the hone marks from new.
    Rings were all 3 lined up on both sides.
    Take it for what its worth.
    I broke it in by the book. It says no were you can't open it up, just don't exceed xxx rpm.
    About 10 miles after I left the dealer, I tried to lift the front wheel. I had plans of keeping it under 4500 rpm. I did. I whacked the throttle in first gear. It lifted the front wheel a little. The engine sputtered and it came back down. All below 4500 RPM. After a minute I figured out it was the traction control.
    What a machine!
