Page 9 of 11 FirstFirst ... 7 8 9 10 11 LastLast
Results 121 to 135 of 152
Thread: Car Tire as Rear Bike Tire - WHATDOYOUTHINK?
  1. #121
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    Quote Originally Posted by kantuckid View Post
    Hmm. Interesting concept to check the brand name or type of failed parts when deciding who to help @ roadside?
    I also don't understand the logic of not putting the "Anonymous" book online. Some say they fear that non-members would seek help. I say "SO WHAT" . What better way to recruit new mwmbers?!
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
  2. #122
    Eastern KY
    While I don't post it(meaning the direct link) I have offered to connect people on occassion. Thats what the book is about as long as we try to protect members from being advertised to the world it's all about being nice in the 1st place.
  3. #123
    Nov 2007
    Pragmatists seem to be in short supply on this forum.
    A car tire will hold up it's end of the motorcycle just fine. The old bikes all had square profile tires.
    The area of a tire on the ground is roughly equal to the weight on the tire and the pressure, leaned or not. The contact patch will be short and wide with the tire vertical and long and thin when leaned over.
    There will be a substantial difference in feel. More effort will be required to turn.
    The peak lean will be reduced. Few riders can go to peak lean anyway.
    No one will criticize someone riding slant 2 airhead, when it's peak corner ability is probably equal to or less than a more modern bike with a car tire. And I am sure that most of you would stop to help.
    Rod
  4. #124
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by ragtoplvr View Post
    So will a brick
    Do you want your NEW bike to handle like an OLD bike?
    In static state this is roughly true. Very few riders care to ride their bikes in a static state.(ie. bike not moving)
    BINGO
    DOUBLE BINGO
    As will handling all the way up to that point
    Sort of like saying; "few riders can use good brakes to the maximum potential, so let's put crappy brakes on our bikes"
    What could possibly go wrong with DIFFERENCE IN FEEL, MORE EFFORT TO TURN, AND REDUCED LEAN ANGLE?
    http://www.youtube.com/watch?v=tF5Cttoi7dY
    Admittedly, this video shows more the lack of RIDER ability, but the bike should not intentionally be the limiting factor by putting sub standard tires on them.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
  5. #125
    Delaware.Dave
    Quote Originally Posted by bdimon View Post
    I followed a Darksider friend on a Honda GL1800 across West Virginia on Route 50. He runs low pressure in his car tire so that the flat part of the tread will remain flat on the road as the sidewall flexes in the curve. At least, that is what he said it would do.
    Here is what I observed. The low pressure caused a lot of bouncing over the bumps as the soft side walls deformed to absorb the impact. When he leaned the bike a little in a corner, the tread did indeed stay flat on the road. However when he leaned over a lot, say 3/4 of the way to grinding the footpegs, the tire tipped onto the edge and only a sliver of the rubber was still on the ground. Hitting a bump in a corner deformed the side wall a LOT! Frankly, I was nervous watching him and worried about the constant sidewall flexing.
    At a stop, you can see how the sharp edges of the tire (the right angle from the bottom tread to the sidewall) was wearing and rounding the edge. This made the tread at this juncture thinner than the middle of the tread. So not only are you cornering on a small sliver of tread, the tread is more worn down.
    I'll stick with the light side, thank you very much.
    I would think the sidewall would wear out very quickly like that. Auto sidewalls are extremely delicate, compared to a thick motorcycle sidewall. Coupled with low air pressure, I'd guess you'd only get hundreds, not thousands, of miles before failure.
  6. #126
    Delaware.Dave
    Rod
    It's not pragmatism, it's darwinism.
    You say a /2 ran a square tire. Well, yeah, but it was 3.5 inches wide. that's 89 mm. A Volkswagen Beetle's tires was twice that width. Comparing a /2 to a modern motorcycle is comparing a propeller plane in the jet age. I'm sure a /2 was a competent mount in it's day, but using a square tire on a modern motorcycle is, at best unnecessarily limiting, and at worst, recklessly dangerous.
  7. #127
    Jun 2005
    Green Bay, WI
    Perhaps, but this is not about being pragmatic. Its about being smart with your life and bike.
    Yes, it'll hold it up, but that is the end of the comparison. So, by that logic, band brakes from old bikes would apply on new bikes?
    Here you are simply flat out WRONG. Might apply to cycle tires from the 70's, but not on modern cycle tires. Modern cycle tires are designed to INCREASE the contact patch area as the bike is leaned over. Car tires cannot do this, and old style motorcycle didn't do it either. So why compromise a definite gain?
    Perhaps to YOU this is acceptable, but that does NOT apply to all riders in general. A lot of the darksiders think what they accept is acceptable for all.
    It's not about PEAK lean. Its about proper control and feel at ALL lean angles. Again, don't assume what is acceptable for YOU applies for all riders.
    Purely speculative with no basis in actual data!
    Oh, by the way, I'll stop to help any rider on the side of the road, no-brand specific or riding style specific.
  8. #128
    Nov 2007
    now to clear things up, I also stop to help harleys and even scooters on the side of the road.
    I use Shinko motorcycle tires, not car tires, I have never had one after the mold release wore off, slip on me. But I know they do not have the traction of a Pilot power. Is this wrong? After all, in an emergency situation I am sure the shinko will slide out before the Power.
    If I were to use a car tire, I would use a run flat as they have the stiff sidewall. If I planned a run to someplace like Alaska, or a 48 state run, or something like that, it would be on my list of things to consider. If I were heading to Arkansas for fun, no way
    Rod
    I am just saying, there are valid reasons for using one, other people have valid reasons for what they ride, like an older K75 rather than the latest and greatest.
    I
  9. #129
    Apr 2008
    SW Ohio
    Wait a minute, so the problem with car tires is that it's risky and perhaps stupid to use them on a bike? But isn't riding risky, stupid to many, and not really a necessity? Imagine how badly the Wright brothers would of been flamed if they posted here 110 years ago!
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
  10. #130
    Jun 2005
    Green Bay, WI
    I understand, though I still don't agree. So we agree to disagree. Riding is risky enough, to me there is no rationale to make it any more risky. Though I do tend to wear my tires to the edges, and bevel my boot edges.
    Oh, and I ride a 19 year old RS Oilhead, just because it is the right bike for me. Like I am sure the feelings are the same for many people who ride Airheads (still have my 76 RS), K75s and /5s.
  11. #131
    Sheboygan, WI
    Cool
    Riding a motorcycle around on broad, perpendicular car tires makes perfect sense.....assuming you also embrace the belief that the earth must too be flat.
    It's been said before and I'll say it again - it's cheap vs. safe, and in the end, neither side of this 'debate' will budge. Ultimately, Darwin will sort it all out.
    To argue it infinitum seems pointless.
  12. #132
    Themason 42906's Avatar
    Jan 2007
    Ridgecrest California
    The guy who said most riders don't use the lean angle available on their bikes has obviously never seen how the BMW Club of San Diego rides ! Spend an afternoon on Mount Palomar with them and you won't make uninformed statements like that.
    Experience is what you get when you don't get what you want.
  13. #133
    Motorsickle Rider brisco's Avatar
    Oct 2010
    De Soto, KS
    Quote Originally Posted by Themason View Post
    I don't think he limited his meaning to most BMW riders in San Diego.
    BMW Club of San Diego ≠ most riders.
    There are other motorcycles besides BMW and other motorcycles in places besides San Diego.
    And I believe he is correct. Most riders don't use the lean angle available.
    Kansas. Eleven curves in three hundred eighteen miles...
    '09 R1200RT '73 R75/5
    N0PGH
    Iron Butt Assoc. #47865
  14. #134
    Eastern KY
    Rod
    I
    As this has become the thread where we can call people out for anything tire related & especially as to car tires on a bike I am in the "hate run flats crowd" They lack traction at a preferred level and ride terribly, while very pricey and I can attest they will not "run flat" for 50 miles!!! I know this from BMW car experience with them. There is a reason people change them out from the cars. Bad e.g.! As to Shinkos, I run them now , like them & at least for my skill level & fairly mild riding style, find them great tires. They are not made in caves nor do they lack sophisticated rubber compounding materials nor have a crude carcass.
    It is a fact that old antique bikes had tires that were sort of tire car like, which gets you not much today...
    I'll say again,read the recent Rider article on the car/bike tire thing.
  15. #135
    Nov 2007
    I always ride on the street. In some carefully selected places I get the edge of the tire down usually once in the life of the tire. On the street, I allow a generous safety margin. I have hit enough gravel, grass clippings, leaves, mud, manure and other spilled stuff with chip and seal to convince myself this is a good strategy.
    If you guys are cornering at maximum lean angles on the street then I believe you are as crazy as the car tire guys. Like the car tire guys, I am sure there are very few accidents, if any.
    Like I said, pragmatism.
    That said, I think I would enjoy a run up mount Palomar.
    Rod
