Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 46
Thread: LC 20 oil additive..
    Registered User R1200RClassic's Avatar
    Jun 2012
    San Mateo, CA
    ok, so I'm not quick to use just any additive in my vehicles, but apart from Techron in my fuel every so often, I've had good luck with LC20 in my duramax truck and BMW X5... seems to keep the engine cleaner (just thru visual inspection thru oil cap)..
    I'm wondering if a dirty little engine like the boxer with it's high amount of oil burn during the breakin period couldn't benefit from LC20 to keep it clean? anyone have any experience with it in their bike? The guys over at BITOG seem to like it..
    http://www.bobistheoilguy.com/forums...2402552&page=1
    http://www.lcdinc.com
    2016 K1600GTL - All Optons
    2012 R1200R - Classic / ESA II, ABS II, ASC, Heated Grips, Sports Windshield, Computer. - GONE
    2005 Honda Shadow 750 Spirit - GONE
    Jul 2008
    Central PA
    Quote Originally Posted by R1200RClassic View Post
    I'd go with STP, the "Racer's Edge". However, only after showering and using "Speed Stick" by MENNEN.
    OK, OK, I just like the old ad jingles
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    Canada and the Alps
    I'm not much for additives other than maybe Chevron Techron which I've used a few times (I haven't used it in years and have 140,000 miles on my ultra smooth idling Honda CR-V) and Dow Corning M Gear Guard in the final drive of my R bikes (no fuzz on my magnetic drain plug ).
    As for engine oil, I've used Mobil 1 synthetic since the first inspection in my 1999 Honda CR-V with 8000 mile oil change intervals (BTW, that oil change interval is excessively early for a quality synthetic oil). The engine internals are ultra clean.
    The Porsche Carrera also sees Mobil 1. The engine internals are ultra clean as well.
    There is too much hype and gabbing going on about oils on oil forums. I have yet to see an oil related engine failure unless the car was abused and neglected. But the additive companies know how to sell based on consumer fear.
    Northern Front Range, CO
    to me, that sounds like a solution in search of a problem.
    Ride Safe, Ride Lots
    Jul 2007
    THE BIG SKY
    +1 A worrier.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Themason 42906's Avatar
    Jan 2007
    Ridgecrest California
    A quality engine oil doesn't need additional additives. Regardless of what the marketing types will tell you, a petroleum engineer in any oil company knows the properties of any possible combination of additives any firm can offer, and each oil manufacturer chooses those additives they feel are best for the oils they sell. There are no dark secrets to the engineers. If the chemicals in the various oil additives were really beneficial, they would be incorporated into the oils themselves by the manufacturers. Most of this stuff is just a way to get you to part with your money.
    Experience is what you get when you don't get what you want.
    Quote Originally Posted by 42906 View Post
    and they seem to be fairly successful at that..... at least from some of us.
    Jun 2012
    San Mateo, CA
    actually it is a fact that the additives do wear out and/or evaporate over time... The life of a good synthetic oil is generally dictated by the length of time the additive package is expected to last. I don't dispute that 99% of the additives are unnecessary but I did read a few good things about this LC20 and it seems with an engine prone to getting a lot of carbon on the piston and heads, this might be helpful in keeping it cleaner, as Techron has been proven to do from the fuel standpoint.
    Sep 2006
    Diamondhead, MS
    Does the name P.T. Barnum ring a bell ?
    '03 R1150R, '03 F650GS, '97DR200SE,'78 Honda CT-90, '77Honda CT-90
    Left Coast Rider
    Nov 2011
    If you want a really clean engine simply position your air intake snorkel behind the front wheel while riding in a rain storm.
    Jun 2012
    San Mateo, CA
    Jul 2007
    THE BIG SKY
    Hey, you asked.
    Kevin Huddy
    Jun 2010
    western NY
    I've had good luck with motor oil.
    Joe,
    .....and it seems with an engine prone to getting a lot of carbon on the piston and heads.......
    really? it is?
