Results 1 to 15 of 19
Thread: elast alternator belt
    motorcycle cowboy Tennessean's Avatar
    Oct 2005
    East Tennessee
    So who has replaced the newer elast alt. belt without using the tool that BMW techs use? There is much info archived here but not much in the way of a successful replacement. My bike has 40k on it and the belt really looks good, no cracks or anything. Wondering if I should let it go for a bit.
    2013 Goldwing
    May 2008
    Racine, WI
    Quote Originally Posted by 2bikemike View Post
    What is the service recommendation? Typically it is better to do it sooner rather than later...
    http://www.r1200gs.info/howto/alt-belt.html
    Dick
    R1200GS '08
    "Hey, where you goin'?" "Nowhere in particular." "Man, I wish I was you." "Well, Hang in there..."
    Registered User rebake's Avatar
    green valley,il
    Replaced the one on my 05gs at 60 thousand miles.I used one of the holes in the pulley with an allen wrench stuck in it.Saw the video online that showed how easy it was.(Maybe on adv rider?) Ed
    Ed Baker
    Registered User NavyDad's Avatar
    Nov 2006
    Chillicothe, Ohio
    Changed the belt on my 04 RT in June. I didn't have any "special" tools. I don't see what the big deal is. I have put 5K on the bike since with no issues.
    May 2008
    Racine, WI
    Quote Originally Posted by rebake View Post
    ...Saw the video online that showed how easy it was
    http://www.youtube.com/watch?v=YzPTPN98x40
    Dick
    R1200GS '08
    Oct 2005
    East Tennessee
    Yeah that looks pretty easy. However, the elast belt is a bit shorter than the one in that video. Do a search for elast, read all about it.
    2013 Goldwing
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    The recommended service interval is 36,000 miles.
    You might not see the accrued aging - cracking can happen on the INSIDE of the belt - after all, that's what rides against the pulleys. Last time I did mine ('04 1150RT, at about 40K), it looked just fine on the outside...
    But once it was off, I discovered that one of the "ribs" was starting to separate longitudinally (in the same direction as the ribs). No way to see that while it was mounted up.
    Eastern KY
    Except: if you have the "older bike" with the poly belt, not the newer elast version, is it OK (or advantageous???) to use the properly installed new version instead-or vice versa?
    Or, simply put, do you install the belt that came on that machine?
    Jul 2006
    Fraser, CO, USA
    IIRC, the original older belts were replaced with a newer version of the poly-v, which entailed replacing the pulleys. This is the belt with the 36K replacement interval. If I understand your question correctly, I'd stick with the newer poly-v for that machine, instead of trying to upgrade to the elast. Just my $0.02
    Conrad Long
    MOA # 82902
    '94 R1100RSA
    '96 R1100RT
    Use the belt designed for your bike.
    You don't have the freewheeling pulley, for one thing.
    Very good thread, very good info. My 04 is in the shop now, and (with almost 40K miles) I was told the alternator belt was toasty. Then there was a problem with none of the stock replacement belts fitting. Methinks the lack of update in the manual might be causing my shop a problem. Now I'm wondering if they have the 200+ dollar tool on hand for tensioning the elast belt.
    R75/6, 2004 R1150RTA.
    Vancouver, B.C. Canada
    Don't give up on BMW over a rubber belt. If they can't tension a belt properly without the fancy tool you might want to look around for a mechanic though! This can be done by feel.
    Apr 2007
    Nacogdoches, TX
    I just use a block of Maple cut to 116 mm, let the upper pulley rest on it and tighten the mounting bolts. It ain't astrophysics.
    '08 BMW R1200RT
    '75 Red R75/6
    Quote Originally Posted by Jeff488 View Post
    And the bottom of the 116mm block of wood is on the lower pulley?
