Results 1 to 15 of 15
Thread: K1300GT bars
    Hank
    Jul 2008
    Whitby, Ontario, Canada
    K1300GT bars
    I find the bars not quite where I want them. I have tried the raise and pllbacks from Suburban. Has anyone found a way, or is someone making replacement bars in a different height/shape?
    Jul 2007
    Evansville, WI
    Where do you need them to move? Up/down, Foward/back?? Angle wrong?
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Hank
    Jul 2008
    I would like a different angle, maybe a little higher. Can't be sure until I try it out, but the grip angle is the first thing that needs to be changed. And I would like to change grips, but that's not so easy when you have the BMW grip warmers!
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by hankhoward View Post
    Post #5 in this thread has instructions.
    http://www.i-bmw.com/showthread.php?t=36398
    Lee 2011 K1300S
    MOA # 30878
    Hank
    Jul 2008
    Thanks for the info, Lee. I will be changing the grips. Now if only I could change the bar angle as easily!
    Wilmington, NC
    I thought this was a thread about what kinds of bars to go to with a K1300
    On the Road
    Aug 2012
    Northern California
    Maybe a set of Heli bar? 1" up 1 1/2" back (I think)
    On the Road
    Aug 2012
    Northern California
    Just checked 1" up and 1 3/8" back. I just got a set and installing them tonight.
    About $120 shipped 3 day to Ca.
    FYI
    On the Road
    Aug 2012
    Northern California
    Boy I better get a real job. around $220 shipped
    Hank
    Jul 2008
    Unhappy
    Ya - I tried them and they are pretty good (although a lot of money for what you get) but I really need to change the angle of the grips. Any ideas??
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Full adjustability: http://tharengineering.com/
    David Brick
    Santa Cruz CA
    2007 R1200R
    Jul 2007
    Evansville, WI
    They'd have their hands full trying to engineer a set of these to a wedge.
    13 C650GT
    MOA 44606
    Santa Cruz CA
    I looked at the parts fiche for the K1300GT...and right you are, Gilly.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Jul 2007
    Evansville, WI
    OK I could see how to engineer it yourself. If you look at this image of the bars Thar makes:
    If you could get a top triple clamp like the one pictured and remove the top bar clamp, including cutting off cleanly the lower saddle of the bar clamp, then you could either bolt that to:
    Part #2, I guess? The "control arm bridge, bottom"? You would lose the ablity to adjsut the height, at least "the factory way", I think he does have a little height adjustment possible in his design, though.
    Or drill a pair of holes through his center section to match the 2 holes that hold the top yoke on (Part #1). You wouldn't be able to adjust the angle up/down though.
    This all assumes that the controls on the bike will fit his bars.
    13 C650GT
    MOA 44606
    Feb 2011
    ROX risers
