Results 1 to 15 of 20
Thread: '93 R100 RS Clock is Broken
    Out There Somewhere bmwrider88's Avatar
    Apr 2008
    Harrisburg, PA
    Any sources for BMW clock repair?
    Is it "worth" it to fix it?
    Thanks in advance.
    Be The Change You Want To See In The World
    Administrator 20774's Avatar
    I'm familiar with the old dial gages and clocks...does the '93 have something like that?
    Check the speedometer section of the Resources and Links thread. I'm sure it can be fixed. As to worth, that's up to you if you want something that came with the bike or if you want to just replace it with something generic and move on.
    Registered User jad01's Avatar
    Houston, TX or Portland, OR
    I had mine repaired by Rick Borth at Oversees Speedometer in Austin. It cost about $80. I had considered buying a used one, but mine was in very good aesthetic condition, and used ones typically go for $75 and up (and they often look worn/faded). If you don't care if it matches exactly, there are a number of after market ones out there that will fit in the same opening (I bought a new VDO clock for my car for $30 and it works great- I think I bought it from egauges).
    Jim
    '78 R80/7 and '84 R100RS (Blues Brothers), '86 K75C (Icy Hot)
    '90 and '93 Mazda Miatas (Jelly Bean and Red Hot), '02 325ci (Blue Streak)
    '96 Giant Upland (big Kendas & freshly greased bearings!)
    South Carolina
    If ya don't mind, I'd like to hijack this thread for one question. When I purchased my 91 R100RT about a month ago the clock didn't work. The previous owner said it was unpluged to keep the battery from going dead. I figgered this was balony and with the help of a friend hooked it back up again. The clock keeps perfect time. I went to start the bike about a hour ago and the battery was allmost dead. this never happened before. So how could one little clock drain the battery???
    AKA SNAPGADGET
    Lifes too short to ride an ugly Motorcycle
    Northern Front Range, CO
    Quote Originally Posted by kgadley01 View Post
    how? because it runs 24/7.
    no, it should not drain the battery, unless you left it unattended and unrun for a few months.
    to the OP= a stock working clock is nice, but $80 or so? To that i would say "not unless your bike is going to be entered in a Concourse level event."
    sometimes, riding a bike with no sense of time at all is the very best thing we can do with our time.
    many just velcro a $5 watch to the handlebar, and it works just dandy.
    Ride Safe, Ride Lots
    doktortim
    Contact Terry Vrla in Hillboro, OR. He has been fixing Airhead instruments for many years.
    "Terry Vrla" terryvrla@hotmail.com
    Lots of happy clients can be found on the Airheads forum at ADVRider.com
    Apr 2012
    Gilbert, AZ
    Mine sits for weeks at a time with the clock running with no ill effects. Perhaps your battery is a little weak?
    2004 R1150RT
    BMW MOA 181289
    Registered User 6659's Avatar
    Jun 2005
    Woodstock, GA
    Why not replace it with a VDO clock with the knob on top instead of on the bottom where it is hard to reach. If time is important to you it shouldn't matter if it says BMW or VDO on the face.
    77 R75/7
    78 R100/7
    93 R100R
    May 2008
    B.P., MN
    Throw the clock in the collection of parts box for a future collector. Ooh, look an original clock! Put in a useful gauge of yer pick like oil pressure. Strap yer $10 Casio on the handlebar before you take off. Or, forget about time and keep track of time by looking at angle of sun and hunger pangs. Less is more. Clocks are for work. Buzz, time to punch in/out.
    Quote Originally Posted by 8ninety8 View Post
    ...forget about time and keep track of time by looking at angle of sun and hunger pangs. Less is more.
    I just received my sun dial from B.C. Cycle Tech... trying to find a RAM mount that will fit...
    Jim
    On the Road
    Jan 2012
    Tucson/Haines, AK
    May 2008
    B.P., MN
    Yes, sun dial can be mounted on top of helmet and read on your Ibad through signal on internet.
    Sweet!
    Jim
    South Carolina
    I think I'll take a look at my battery. I was told it was new, but new when??? three years ago??? or did it come from Wal-mart???
    AKA SNAPGADGET
    Registered User helmut_head's Avatar
    Feb 2011
    Michitucky
    Wear a watch.
    Helmut always wears a Helmet.
