Results 1 to 2 of 2
Thread: Can I lower the seat on my '06 K1200LT?
    Brucebo
    I have seen discussions on lowering the K1200LT seats on the earlier models. Some modify the mounting system and grind down a bit of plastic, while others dig right under the vinyl and reshape their foam.
    My bike has heated seats, and I'm quite leery of mods that require cutting the vinyl &/or foam.
    Does anyone have a solid mechanical technique for lowering the seat mount on later model KLT's?.
    Thanks,
    BruceBohttp://forums.bmwmoa.org/images/smilies/ilikebikes.pnghttp://forums.bmwmoa.org/images/smilies/brow.gif
    Registered User johnbaker15's Avatar
    Sep 2011
    Chelmsford, Mass
    Bruce,
    I assume you know that the seat has an adjustment bar, it has two positions. If it is in the lower position there are a couple other things you can do. One is remove the bar, others have done it and you get another 1/2 inch. The second one is to reduce the preload on the rear shock, flip up the seat and turn it counter clockwise. HTH
    BMW 2005 K1200LT
    Suzuki 1979 GS1000E
