Results 1 to 15 of 26
Thread: work stands
    work stands
    howdy all,
    i want to ask: what does everybody like for a work stand?
    i have an R90/6 and i would like to get the front wheel higher off the ground than the center-stand gets it.
    i'd also like to have the rear wheel off the ground without asking my wife to lift up on the rear of the bike.
    thanks in advance,
    -eric
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    Quote Originally Posted by ezwicky View Post
    howdy all,
    thanks in advance,
    -eric
    It all depends on how high I need to raise things. I sometimes put the center stand on one or more lengths of 2x6.
    To keep the rear off the ground, I put an adjustable jack-stand under rear axle.
    For more height, I have an Aerostich Wheel Crate Workstand (steel model).
    Justin in Somerville, MA
    _________________________
    76 R75/6, 78 P200E, 63 VBB
    Lots of bicycles
    Your ultimate goal is a lift.
    Why waste the $$ on interim solutions?
    Gandalf
    Apr 2009
    Marlow nh
    Rear wheel higher off the ground
    I had to do this to fix a flat
    Wisconsin and Florida
    I usually hoist the whole bike off the ground or one end or the other
    with a comealong ratchet type fence stretcher to the rafters in one location
    Or an electric chain hoist in another location
    If you only need 4 to 6 inches you can use a stack of 2"x material about 3 ft long
    put bike on centerstand on hard surface back bike onto one 2x to make centerstand lift easier then kick the board out
    tie centerstand forward to front motormount bolts or other so it won't fold up
    put 2 x 8 end against inside of far side of stand away from you
    lean bike toward you and push end under far centerstand leg
    lean bike away from you and kick near end under nearside centerstand leg
    then repeat the process with 2x6 on top of the 2x8
    then repeat the process with 2x4 on top of the 2x6 if necessary
    you can get quite high with no back strain or serious muscle work
    then use jack or lever to teeter the bike to elevate whichever end you need up and block it there with something
    go to work
    Registered User PeoriaMac's Avatar
    Aug 2003
    Washington, Illinois
    If you do the bike on the 2 X 4 process: remember to loop a belt, comealong, or something solid from the crossbeam of the center stand to the crossover tube of the exhaust. This prevents the embassassing event of the rolling foward and resting on the oil pan...or in the worse case scenerio, on the front forks, oil pan and final drive... Trust me on this...
    Mac
    Mac
    1986 R80RT, 2005 R1200GS
    Livin' Large On The Lake
    Dec 2007
    Reno, NV
    Quote Originally Posted by PeoriaMac View Post
    Mac
    Been there, done that. Bike looked like some sort of Airhead snowmobile!
    Aug 2003
    Glad to know I'm not alone.
    Mac
    Aug 2010
    Calgary, AB. Canada
    Works Stands
    Justin, Saw your comment with regards to Aerostich Wheel Crate Workstand (steel model) and I want to say Thank you. This is just what I have been looking for as I am down sizing and the bike lift I have takes up to much room and I am not getting any younger moving this beast around. Googled these people and I for one didn't know they even existed let alone in North America. Great and very interesting place to brows. Reminds me of when I was a kid as the best time of year is now when we got the Simpson Sears and Eaton catalogue's back in the day!
    Rick MacPherson
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    Pismo Beach, CA
    I've jury rigged quite a bit of stuff in my life, but I don't think I'd care to use this set up.
    Not really tall enough to be able to comfortably work on the engine, and using a scissors lift on top of the rail to raise the bike seems like it's asking for it.
    Kinda like this...
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Quote Originally Posted by stanley83 View Post
    thanks. i did this trick and it's what i was looking for as far as the front wheel goes.
    BMWMOA #182796
    '76 R90/6
    Registered User krpntr's Avatar
    Mt Vernon WA
    I use two milk crates and a 2"x 12"x 8' plank. I was able to stabilize it by attaching a spreader 2x2 to the front box. (Just like the three hundred dollar aluminum one.) I thought it would be a bit sketchy but after taking the exhaust nuts off with out rocking the bike I was able to relax and wrench away. There was a bit of a sag to the plank but a pair of 2x2 's screwed to the edges made it solid. Another milk crate for a seat, and I could sit and comfortably work on the heads and cylinders. Plus it was the perfect height to peer into the headlight bucket.
    John D'oh
    Aug 2006
    Close to Fort Worth Texas
    Wood Work Stand from the MOA News years ago...
    It took me a while to find the drawing I made. This seemed like a good idea 20 years ago but now the cost of the materials might be an issue. Lash the front or rear wheel down and move the opposite table out of the way for unrestricted access or just leave them together for a great work bench. I took the basic dimensions from the original drawing. I'd suggest doing a chalk layout on the floor of your garage just to be sure. I use the Handy Lift myself. Good used ones go for around $400.00 - $500.00 in this area and show up on Craigs list every 6 months or so. What would the wood cost to make the table as drawn? I might add a largish flat steel plate to place under the center stand. OH~! drawing not to scale :-)
    Jun 2007
    Minneapolis, MN
    What a cool sketch and neat idea! Impressive group we have here!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Registered User brewmeister's Avatar
    May 2009
    along the wisconsin river here in central wisconsin
    here's a nice lift
