Results 1 to 15 of 26
Thread: Mesh gear
    Mesh gear
    Never owned or tried any mesh gear, and have a few questions of those who have.
    First is it really cooler than say a tee shirt & cotton pants / jeans?
    What happens when it rains? do you still need to put on a rain suit? or does it somehow channel the water out?
    I'm considering a pair of pants with zip off legs.
    Good mesh gear is cooler than a T shirt and jeans. More of your body is shaded than with a T shirt and airflow is better than jeans. It is also much better protection if built well and properly fitted.
    Some mesh gear comes with rain liners for jacket and pants. Some doesn't. If not, a rainsuit is in order although in hot weather and brief storms or showers just getting wet and drying later feels very good.
    The huge danger with mesh gear is dehydration but you face it just the same in a T shirt and jeans I guess. This whole issue is very dependent on bike/fairing type, and whether we are talking hot dry (west) or hot humid (east and other places).
    I use a mesh jacket for short trips. When traveling I use a Darien jacket and either mesh or Roadcrafter pants, depending.
    Jul 2011
    Mechanicsburg, PA
    Funny you should ask...
    Yes, mesh gear is cooler than jeans/tee-shirt.
    And, yes, you do need to wear a rain suit when it rains.
    I just got home from riding in the rain sans rain suit, and I was soaked. The rain went through my jacket and got me fairly wet underneath. Interestingly, the rain that collected in my sleeves seemed to have pooled in my elbow armor, because when I would move my arm it would all run out wherever.
    One nice thing, though; the jacket will probably be dry in the morning.
    The "Miracle of Modern Technology" is that we get anything done using it...
    Tame Racing Driver Stig's Avatar
    Dec 2009
    Hudson Valley, NY
    All of the above is correct. Give this a read for a better understanding of how to stay cool during warm & humid temps:
    http://www.ironbutt.com/ibmagazine/I..._62-66_Hot.pdf
    Craig
    New York's Hudson Valley Region
    2009 R1200RT
    MOA #146131 IBA #55715
    Registered User ezec's Avatar
    Aug 2011
    Arkansas
    I'm no expert but the above article is the best I have read on hot weather riding.
    2010 R1200RT
    GO HOGS!
    Registered User Brian-NC's Avatar
    Feb 2006
    Charlotte, NC
    Quote Originally Posted by 71243 View Post
    The best money can buy can be found at www.motoport.com
    Not cheap by any means but will save your hide. One thought about riding in the heat. I have a rainsuit but if it's 95 - 100 degrees and high humidity, I welcome a rain shower. I don't keep anything in my pockets that would be ruined and the rain helps cool you down. By the time I get where I'm going, I'm usually almost dry.
    Brian-NC
    (Matthews)
    Current bike
    2010 RT Ostra Grey
    Apr 2012
    Maryland
    Mesh works well from about 80-95 degrees.
    Mar 2012
    Las Vegas
    I "semi-retired" to Las Vegas and ride at least once or twice a month to SoCal across the desert. I ride with a Veskimo cooling vest and could not/would not do the trip without it. I own mesh gear from Olympia, Revit and Bates and have made the desert crossing in each. I recently bought a Klim Badlands jacket and pants for a trip to Alaska. Two subsequent trips to SoCal in temps of up to 110 have proven to me that the Veskimo keeps me cooler in the Klim (not mesh) gear than in any of the mesh gear since the hot wind is kept off and the Klim gear holds the cold of the Veskimo in ether than the mesh. If I use the built in kidney belt on the Klim jacket, the area against my back and belly actually get downright cold. The article posted indicating that it is necessary to keep the hot air out when it is above 93 or so is right on. Great article, thanks for posting it.
    RK Ryder
    London, Ontario
    Not all mesh gear is the same. When I used to wear my Joe Rocket mesh jacket, the wind rushed through the jacket, almost as if I wasn't wearing one. My Motoport mesh gear lets the air in, but not to the degree that does the Joe Rocket jacket does. I assume that it is because there is so much more armour in the M.P. Hence I figure the M.P. gear is a compromise between mesh and non-mesh gear.
    Paul
    Knights of the Roundel #333
    AZ
    Awesome article Stig. Thank you for sharing!
    MOA #107139
    RA #28511
    YB #2005
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    A mesh jacket is cool.
    A t-shirt and jeans is kewel.
    But since having your road rash scrubbed by an ER nurse is definitely NOT kewel, I'd rather just be cool.
    pete
    Olympia makes a mesh jacket with zip out wind/rain liner and zip out quilt insulation liner. Pretty versatile...
    Currently, when it's above 65 degrees I ride without any liner, and a long sleeve shirt. Above 80 degrees I peel off the long sleeve shirt and wear the short sleeve shirt I have on underneath...all are wick-dry material.
    I suspect the wind/rain liner goes on under 60, and the insulation under 50.
    My bike has full fairing...
    Eastern KY
    Lawrence of Arabia wore white-somebody needs to ask: why not a MC jacket that's white? No dirt comments please
    Quote Originally Posted by kantuckid View Post
    If I had to guess? I'd say they likely wouldn't sell well enough?
    Not enough tuff-guy image? Borderline feminine ?
    I have seen two, [or the same brand twice] that is sand color? I'm thinking maybe having something to do with lessons learned in Iraq?
    Jan 2008
    Jacksonville, FL
    Smile
    All of my riding jackets are mesh. In hot weather I wear a long sleeve wicking material shirt as it seems cooler in humid conditions than a short sleeve. For cooler/wet weather liners can be added. The only exception is my BMW Venting Machine jacket that has no liner, a rain jacket that fits over the BMW jacket keeps me dry and if need be warm. Ride Safe
    Cave Contents: 1980 R100RT/Ural Sidecar, 2004 R1200CLC, 2006 HD FSXTI
    Ride Safe
