Results 1 to 15 of 19
Thread: 2003 r1150rt oil filter
    This my first BMW oil head,sorry to sound ignorant but where is the oil filter?
    Feb 2005
    Trinity, NC
    It is in a cavity underneath the engine. You will need a thin walled filter wrench to remove and install it.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Vancouver, B.C. Canada
    Or this one. Less wordy, more concise and WAY better pictures!
    http://www.amazon.com/Haynes-R850-11...r1150RT+manual
    Mar 2007
    15 M. E. Tampa
    where
    As they say - underneath the engine, left front corner. You don't have to remove any plastic to see it or to change it. You just have to be willing to lie on the ground with all the fire ants to see it.
    Quote Originally Posted by flars View Post
    Since he has an 1150RT he is going to have to remove the 4 X 3mm screws to get the plastic belly pan off so he can see the oil filter in the bottom of the engine eh?
    And the drain plug is under there too.
    As for the fire ants, dang! I'm not changing my oil in Florida!
    Mar 2007
    15 M. E. Tampa
    1150
    Pretty sure the 1150 filter is right there in the open, too. The belly piece is just two long pieces on the sides. The center remains open...I only say this because I only drag one hex wrench out to the bike when I change the oil.
    [Oh, crap - now I am starting to doubt my memory. Now I have to go home and look at my 1150, darn you.]
    I'm assuming the 1150 tupperware is pretty much the same as the 1100 tupperware which is in 3 pieces. Left side, right side and before you take those off the bottom (belly pan) needs to come off. Now I have to check the Max BMW fiche darn you!
    Yeah.. I just took a look. It's there and it needs to come off on an 1150 also. Click on "Vehicle Trim and then painted parts. The bottom pan is part number 5.
    http://www.maxbmwmotorcycles.com/fic...0&rnd=05012012
    Incorrect my Canuckian friend.
    I can change the oil on my 2004 R1150RT WITHOUT removing the belly pan.
    Just did it this past weekend.
    The belly pan is curved in a way to allow you to access both the drain plug and
    oil filter. Unlike my wife's K1200RS.
    Feb 2005
    Trinity, NC
    The belly pan is the same part number on the 1100 and 1150RT. As stated above, it is carved out so the filter and drain are exposed without removing the part.
    May 2012
    Escondido
    Quote Originally Posted by TexasMule View Post
    Why not just remove the four screws and the belly pan? You'd have better access to catch the oil, and to clean up the area.
    2000 R1100RT-P
    Quote Originally Posted by Bmandiego View Post
    Precisely why I do it every time.
    I have to admit the boys caught me out though! I've never even _tried_ to do it without removing the belly pan and did not think it was possible to change my oil and not make a big old mess!
    So I stand corrected. Sorry if I misled someone. Leave it on and drain away!
    Not me though. I like plenty of room and lots of rags. I remove the little rocks and crap from the pan while I'm at it.
    I change my oil every 3K. Every 6K I adjust the valves/throttle bodies/change the trans/final drive/engine oil, etc. That's when I drop the pan.
    There is plenty of room with the cutout in the pan to avoid any mess, unless your extremely clumsy....
    YMMV
    Jun 2012
    Paramus, NJ
    Oil Filter Wrench Size "94 R1150RT
    Okay,
    Don't want to remove the belly pan.
    I know where the filter is but can anyone tell me the size and where I can buy one?
    Peter
    YMMV
    total and complete waste of time, money and natural resources, with absolutely no proven benefit.
    we have left the 1950s and 60s behind us. better would be to just follow the manufacturer's recommendations of 6K/12K fluid changes.
