Norms 427
Norm
Thanks for posting the pic ... it's a little hard to read. What source is that? What does the chart say for 10w-40?
The wisdom of a range of lower temps for starting a cold engine is very obvious because sitting overnight the oil temp is very close to ambient temp. Engine starts usually represent the greatest amount of wear on an engine.
But I am not understanding a limitation on upper temps (if, in fact, that is what the chart is trying to represent). My oil temp gauge on my RT while cruising doesn't read appreciably different whether I'm riding in 40* F or 95* F (at least that my old eyes can tell).
Also, I have a sports car with an external oil cooler without any thermostat and the difference between 40* F and 95* F is only a very few degrees of oil temp, nothing worth switching to a higher viscosity for. The difference in the two vehicles I've mentioned is probably that my car doesn't have a thermostat on the oil cooler (and shows a bit of increased oil temp) whereas the RT has a oil thermostat and therefore nicely compensates for outside air temps.
Thanks.
Norm
