Results 1 to 7 of 7
Thread: low beam bulb replacement
    PDOGGER
    I need to replace my low beam on my r1150rt for preventive maint. I know how to access the bulb but am having trouble removing the black plug with the wire leads. Does it just pull off or is there a release. Thanks for any help
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    PDOGGER
    bulb replacement
    Thanks for the tip but the video does not show the removal of the black electrical plug. Wondering if it just pulls off. I guess mine is stuck to the bulb.
    Northern Front Range, CO
    if its a 3-prong connector, just pull. maybe a spritz of some WD40 to loosen things up a bit.
    Ride Safe, Ride Lots
    Jun 2011
    N.E. Ohio
    Yup, just pulls off.
    Registered User Bmandiego's Avatar
    May 2012
    Escondido
    The one connector on my 2000 r1100rt just pulled off.
    2000 R1100RT-P
    PDOGGER
    bulb replacement
    Thanks for the replies guys, I will just pull a little harder.
