Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 70
Thread: Dreaded oil thread. So sue me...
    Left Coast Rider
    Nov 2011
    Apologies in advance for the subject.
    Buddy of mine just bought an R1200S. What oil grade should he be using? Synthetic Mobil 1 15W-50 (car oil) ok?
    Jul 2007
    THE BIG SKY
    Did he get an owner's manual? Good advice in that.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    did he get an owner's manual? Good advice in that.
    +1
    Dave
    Clovis, NM
    Tell you what. Save yourself some money.
    Send everyone on the forum a $5 bill and save yourself some attorney fees.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Jun 2005
    Green Bay, WI
    No, Mobil 1 15W50 is not a suitable "long term" oil for a motorcycle. Note I said long term. For one oil change cycle, or to get the bike home on a trip, fine. But for extended miles and use a motorcycle specific oil is the better choice. These engines still need the benefit of ZDDP and similar additives that are now only common to motorcycle specific oils and some brands of "racing" oils.
    I used to use Mobil 1 automotive oil. That is until I found out the formulation changed and the ZDDP additives were replaced. I now use Valvoline Full Synthetic 20W50 Racing oil which does contain high amounts of ZDDP. Oh, and my bike now has 168,000 trouble free miles on it, so the right oils may have some impact on that.
    There, oil thread started, jump on everyone!
    May 2011
    South Kentucky
    Quote Originally Posted by 32232 View Post
    +1
    +1
    Anthony S.
    2012 R1200GS
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by ANDYVH View Post
    Thank you, Andy. When was the formulation for Mobil 1 15w-50 changed? I've been using it for years with excellent results. I suspect this is a recent change?
    And to everyone else, no owner's manual. Please send me your addresses so I can put $5 in the mail for you.
    Urbana, IL
    Quote Originally Posted by BC1100S View Post
    I understood that the zinc additive was reduced for the lighter weight oils, like for water cooled engines, but was optional for the heavier weights since they are not used in the larger fleet of cars.
    My other bike is a BMW.
    P Monk
    May 2005
    Port Neches, Texas
    Mobil 1 not a recent change
    I used to work with a guy who changed jobs from Mobil fuels to lubricants about 10+ years ago. I asked him if there was any real difference and he sent a lot of information, but bottom line is car oil was different from motorcycle oil. This was when Mobil first started making the MC oil. Probably 10-15 yrs ago.
    P. Monk
    74 R90/6 (also know by bride as the Black Hole). 09 R1200 GS. My wife, 1953 model who has survived aplastic anemia and a bone marrow transplant.
    Albuquerque, NM
    Quote Originally Posted by dpmonk View Post
    It needs to be different when the transmission runs in same oil as the motor.
    Otherwise it does not need to be different.
    This describes all boxers and most K-bikes.
    ZDDP is bunk.
    Kent Christensen
    21482
    Then download one directly from BMW
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by cjack View Post
    This is from October 2011....
    Note the applications for 15W-50 "....racing and flat tappet applications."
    http://www.mobiloil.com/usa-english/...duct_guide.pdf
    Left Coast Rider
    Nov 2011
    Then download one...
    Thanks for that!
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Am I reading this correctly that this would be SF or better, which is automotive oil pretty much.
    Since dry clutch, no need to use MC specific oil?
    John.
    Urbana, IL
    Quote Originally Posted by JStrube View Post
    Actually, back when a whole bunch of oils were tested independently, BMW (Spectrol) oil tested very well. Mobil 1 was ok, but not at the top anti wear wise. I don't think any premium oil will be noticeably bad for these engines. I, however, will continue to use oil specified (JASO-MA) for wet clutch engines in the wet clutch engines.
