Results 1 to 12 of 12
Thread: Pulling trailer with R1200RT
    Plasterman tgf429's Avatar
    Aug 2006
    Tiffin, Iowa
    What weights of trailers are people pulling with their RT's? Do you think the drive train will hold up as well as my LT did
    Nov 2005
    Fairfax, VA
    I pulled a Bushtec Quantum with several K12LT's, and I am currently using a UniGo. I am also now on an R12RT. I would not hesitate to pull a Quantum with the RT.
    The trailer weight is not so much a drivetrain concern (remember, people used to/still do pull camper trailers with R100RT's), as it is a frame/subframe and brakes issue.
    The frame/subframe on the R12 has proven to not be an issue, as shown by lots of R12RT's with Bushtec and DMC hitches.
    The brakes on the RT are at least as good as the LT's and they are handling something like 250+ lbs less of bike weiht, to boot -- so no issue there.
    Mark Neblett
    Fairfax, VA
    #32806
    Jul 2010
    Lansdale, PA
    I have a Bushtec Turbo+2 that I use for camping and going to the beach. It weighs 140 lbs with a 350 GVW capacity. It pulls like a dream and you almost forget it's back there. I actually think it stabilizes the ride like a tail on a kite. The bike has plenty of power with two up cruising on the expressway and doesn't seem to stress it at all. It is probably easier on the frame / suspension since the trailer hitch tongue weight of 10%-15% of load is no more than 50 lbs.
    I am very interested in the Bushtec trailers that you have mentioned. Is there anyway you could post a picture so I can see how they look with your bike. I also have a 1200RT...Thanks
    Jul 2010
    Lansdale, PA
    Bushtec Turbo+2 pictures
    Here's the trailer that was painted by Bushtec to match the Piedmont red (sent them the front fender to match).
    Also a photo of the Bushtec trailer hitch that I installed. Good fit and clear instructions.
    Sacramento, California
    Quote Originally Posted by j.castiglia View Post
    And now you better spent the money to paint that 49L Top case to match the rest of this beautiful set up.
    color match paint
    That's exactly what I was thinking!
    Looks like a nice setup, interested in doing the same thing.
    Question, should I have my expert ( $$) paint shop paint mine, or the bushtec folks?
    Reel Job
    2011 R1200RT/ Polar Silver
    Aug 2006
    Tiffin, Iowa
    Nice. I will post some of mine if I can find them. Beware of the Dauntless (DMC) hitch, it has clearance issues and terrible customer service.
    Fenwick, Ontario Canada
    If I can pull a Bushtec Quantum with a 35 year old Airhead you won't have any trouble with your 1200RT.
    They also sell hitches, and are excellent to deal with!
    Knights of the Roundel #333
    Thank you so much for the pictures and the information. I really how it looks on the RT1200. I was thinking about the ZZ Trailer, but after seeing how great yours looks, I think I may have changed my mind...and don't sweat the tour pack, your set-up looks great. Maybe I will see you on the road someday.
    Bushtec trailer
    Quote Originally Posted by JochenWoern View Post
    I just purchased a 1996 bushtec trailer this past weekend, to tow with a 2011 Rt 1200RT. ( on EBay)
    What year is your cycle, and did you buy your hitch from bushtec?
    What lbs. do you run the air at ?
    Mines the same color as yours, but my Cycle is "polar silver"/ baby blue !
    Any info will help, as I need hitch, wiring, paint job, spare tire, and to take apart and paint the frame, and square it away for a ride to the end and back from RI. !
    My top box is already color matched thou !
    Reel Job
    Polar Silver 2011 R1200RT
    Steve
    401-741-6551
    Jul 2010
    Lansdale, PA
    Bushtec hitch
    If you go to the Bushtec Trailer Hitches for BMW site you will see the hitch for your bike. There is also a link to a 10 page installation manual for the hitch at that location.
    They also have the electrical kit for the lighting system that is compatible with the Can Bus. There are two kits at:
    R1200RT harness 1
    "The relay isolator easily and properly connects and isolates your trailers electrical load from the motorcycles factory wiring, fuses, relays and computers and electronics. The main power and ground comes from the battery. Plug-n-Play Subharness for the BMW R1200RT motorcycle is used in lieu of the universal subharness. THIS PART IS REQUIRED IF YOUR MOTORCYCLE HAS A CAN BUS ELECTRICAL SYSTEM."
    AND
    R1200RT harness 2
    "Module for Can Bus electrical system for the BMW R1200RT only. Use the Can Bus Module in lieu of the electronic relay isolator package. THIS PART IS REQUIRED IF YOUR MOTORCYCLE HAS A CAN BUS ELECTRICAL SYSTEM."
    Call them to find out which one to use.
    The kit is excellent and plugs right in without having to modify or cut any wires.
    The installation was very straight forward and fit the frame perfectly.
    Last edited by j.castiglia; 04-07-2015 at 05:57 PM. Reason: Additional information
