Results 1 to 11 of 11
Thread: K1100 not starting except on neutral
    Apr 2005
    Quebec, Canada
    The starter does not work when in first gear.
    Only in neutral.
    Must be something in the sidestand... but where should I look?
    Thanks.
    JPK1100
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Your clutch lever switch has failed.
    This switch tells the bike that the clutch lever is pulled in (you wouldn't want it to start with the bike in gear AND the clutch engaged).
    61 31 1 459 569 SWITCH $34.42
    It is located on the clutch lever perch just below the choke lever. The plug end is under the fuel tank.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2005
    Quebec, Canada
    Thanks Lee but...
    I am leaving Monday morning for the Rally in Sedalia .
    Any problem with such a long trip (1600 miles) wiith this problem not fixed?
    JPK1100
    Apr 2008
    SW Ohio
    Only problem would be if the neutral switch failed too!
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Or if you stall it with an oncoming truck bearing down on you. (Can be a bitch trying to find neutral in a moment of panic!)
    Have fun at the rally. Fix it when you get home.
    Mine, Hers, Spare
    Layton layton's Avatar
    Mar 2005
    Ft. Smith Ar
    Find a dealer along the way and pick up the part. When you get to the rally start taking the bike apart.......stand there and scratch your head......you will have plenty of help.....
    Dec 2004
    Winnebago, Il
    If you get lucky like I did on my 85 K100RT the connector under the tank had just worked loose over time. Reconnected this and bike now starts like it should.
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
    Apr 2005
    Quebec, Canada
    Thanks,
    I'm on my way home, back from the rally.
    I'll check the connections first.
    Jpk1100.
    Registered User amtoro's Avatar
    Jun 2012
    Atlanta, GA
    I may be mistaken but I thought this is the way it is supposed to work, at least on my R...
    Starts fine in any gear as long as the clutch lever is depressed, but if I go into gear and the kickstand is out, the engine shuts off. It also does not start in any gear (only in neutral) even with the lever depressed if the kickstand is out.
    '04 R1150 RT
    Apr 2005
    Quebec, Canada
    Well... Went to Sedalia. Without any problem save the annoyance.
    But now is the time to fix the problem.
    But how do you take this switch apart? You unscrew or you pull?
    JPK1100.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Unscrew. Next to impossible to get wrench on the hex of the switch. The factory usually tightens these way too tight, so they are hard to get out without destroying them. Unplug the connector first, then test with an ohm meter. If it is indeed bad, you might cut off the wire and use a deep socket to remove it. If it's bad, there is no problem if you need to break off the outer part of the switch to get to the hex.
    When installing the new one, finger tighten then back off 1/8 turn. It's not going to come unscrewed by itself and will be much easier to remove in the future.
    Mine, Hers, Spare
