Results 1 to 15 of 21
Thread: Cleaning Black Plastic Below Windshield
    Eschewing Obfuscation VTBeemer's Avatar
    Nov 2009
    Vermont
    Did my due diligence looking in the archives for cleaning tips for cleaning the black plastic below the windshield - and found none. Just finished a 4500 mile trip from Vermont to Manitoba and back. Estimate I killed 10% of the bugs along the 2 Provinces and 8 States. Cleaned up the 2007 RT and looks good except for that plastic that looks more grey than black. Local Beemer shop suggested 'any tire cleaner product'. Ones I looked at had petroleum or corrosive warnings.
    Any suggestions?
    Patrick
    R1200 RT
    K100RS
    R90S
    Jun 2012
    Olympia, WA
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Give it a good cleaning with any bike wash product, S100 or the like. Note that these are aggressive detergents containing surfactants and will discolour surfaces if 100% of the residue isn't removed. Rinse thoroughly, then do it again.
    I really like Mothers Back to Black as a surface treatment for black bike plastics; it isn't glossy and doesn't leave residue like other products. It leaves a nice matte sheen.
    Dave
    '06 Triumph Scrambler (Trans-Labrador veteran)
    The graying is more likely sun damage, other aging, or the effects of previously used chemicals. The back to black recommendation is likely the thing you need, as you aren't likely to be able to wash off the aging.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Mother's is good stuff; any shop - bike or car - will sell a spray specifically to "re-blacken" plastics. WD-40 and Teflon lube also work.
    Nov 2009
    Vermont
    Thanks very much for the sage advice. Will try the product suggestions. Just did not want to try a product that gives a short term fix, but long term problem.
    Patrick
    R1200 RT
    K100RS
    R90S
    Jun 2007
    Portsmouth, NH
    There is a product called "Back to Black" (or something like that) which may help.
    I once damaged the black plastic on my front wheel fender by accidentally using an abrasive wheel cleaner on the front wheel.
    Amazingly, applying a coat of clear walnut oil onto the damaged area completely refurbished the plastic back to factory specs. I hear that peanut oil will do the same.
    Apr 2010
    Western MA
    For years, I've used 303 Aerospace Protectant for all my vehicles' black trim. I also use it for the kayaks and other plastics that benefit from UV protection. It is the UV that is the major contributor to the graying of the black plastic bits.
    I also use Griots SpeedShine on top of the 303 if I want a slight bit of a sheen.
    HTH,
    Theo
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    I've used Back To Black with good results (after washing the bike and letting it dry, of course).
    Mark
    2015 R 1200 GS Adventure
    Registered User R1200RClassic's Avatar
    Jun 2012
    San Mateo, CA
    Quote Originally Posted by THEO View Post
    HTH,
    303 is by far the best stuff for clean/protect black trim IMHO... and what ever you do, DONT use Armorall....
    I used to use Silicone Spray also but I think many are now saying not to due to the ill effects of the evaporative suspension (basically the petroleum distillate part) eroding the plastic/rubber..
    2016 K1600GTL - All Optons
    2012 R1200R - Classic / ESA II, ABS II, ASC, Heated Grips, Sports Windshield, Computer. - GONE
    2005 Honda Shadow 750 Spirit - GONE
    Nov 2009
    Vermont
    Appreciate the great suggestions especially the UV protectant option of some products. Mothers' Back to Black was available locally, tried it and it took a few years off the bike. Will explore the other suggestions. Big thanks for all options.
    Patrick
    R1200 RT
    K100RS
    R90S
    Rider on Ramald
    Jul 2007
    Saint Louis, MO
    Quote Originally Posted by Lee200 View Post
    And this is why I always clean bugs off my plastics with creamy peanut butter.
    Armor all is in no way harmful to the surface, but it doesn't last long, offers zero UV protection, and may migrate or "wash down" to places you don't want it to be. Back to black lasts longer and stays put better. 303 is where it's at.
    R75/6, Non functioning 2014 FJR1300A
    Apr 2012
    Gilbert, AZ
    Where can one obtain this 303 magic elixir? Is it readily available at your FLAPS or home center?
