Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: Plugs anti-seize or not
    Oct 2010
    Manley Hot Springs Alaska
    Cool Plugs anti-seize or not
    I just love it when 2 gurus differ,one says never and the other says always use anti-seize on plugs w/reduced torque.I intend to us it anyway. Any thoughts. Gurus yea,yea!!!
    Mar 2008
    DeLand Florida
    I always use it, and tighten them enough to crush the washer.
    Albuquerque, NM
    Gurus--what a joke.
    The folks that make spark plugs and the folks that make engines say no antiseize.
    Kent Christensen
    21482
    New Hampshire, USA
    I've never had any issues with plugs sticking in cylinder threads as long as they were properly installed to begin with. Maybe I've just been lucky? No antiseize for me on sparkplugs, though I ALWAYS use it on the exhaust port threads.
    BMWs in my garage: 1982 R65LS, 1978 R100/7
    Braintree, MA
    In 45 years of doing my own vehicle maint, I've never used the stuff.
    -Tom (KA1TOX)
    Registered User miairhead's Avatar
    Jul 2008
    Otsego, Michigan
    I trust Oak
    Oak says NEVER use on plugs. Tom Cutter I think advise against it too.
    Tom
    '84 R100RT '04 CLC(gone) Honda NT700V
    BMW
    Beer Motorcycles Women
    Well, in the BMW manual it says to use graphite grease. Personally I apply a very light coat when changing plugs, but that's about it
    // 1975 BMW R90/6 (cafe'd) // 1957 BMW R60 (in pieces) // 1967 Aermacchi/H-D Sprint 250 SS (custom special) // 1967 Moto Guzzi V700 (current restoration)
    http://symphonyofshrapnel.blogspot.com
    Mar 2008
    DeLand Florida
    Some reading for your consideration.
    http://mechanicsupport.blogspot.com/...nti-seize.html
    http://www.avweb.com/news/maint/spar..._198595-1.html
    http://www.aircraftspruce.com/catalo.../antiseize.php
    That said, the newer plugs seem to be coated with a material that makes it no longer needed.
    http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
    I may stop using it since I now use NGK plugs in my bike.
    May 2012
    VA
    I look at anti-seize similar to peanut-butter - perhaps because of the similar consistency. Some places really need it, but it probably wont hurt putting a thin coat on most any metal threads. Granted, it is messy and unnecessary but generally won't damage the threads or cause other problems - unless it is used around brakes or other grease-free areas. Some uses, like aluminum to aluminum threads on the exhaust nuts require anti-seize.
    Some industries (i.e. nuclear) put anti-seize on nearly all fasteners, but it is really needed on materials which tend to gall in contact such as stainless and aluminum. I have used anti-seize on spark plug threads a few times: it is messy and has no benefit but has never caused any problems.
    Stan
    AH# 13238
    doktortim
    In servicing Euro alloy heads for many years, the problems I have seen always have to do with, "if some is good, more is better and too much is just enough". It turns into bubble gum consistancy and has to be removed with a thread chaser. If you can't just loosen the plug and turn it out with fingers, it's a problem.
    I use just two drops of light machine oil. No worries.
    Sep 2003
    Virginia Beach
    Some is good, more is better, too much is just about right - Jerry Lee Lewis
    Virginia Beach
    current:14 R1200RT 75 R60/6
    past: 11 R1200RT 10 R1200RT 03 R1200CLC
    Understanding is everything. A little smear of anti-seize in and of itself does no harm. But it reduces the measured tightening torque by from 25% to maybe 40% because the friction component of the torque resistance is reduced. What the wrench senses is a combination of friction and clamping force. So if anti-seize has been used and a person sets a torque wrench to the specified torque the resulting clamping force may exceed the thread strength and the threads will strip.
    If anti-seize has previously been used some remains. Then if new plugs are installed by a person who doesn't know it was there - the threads may strip. That is the downside.
    On low miles-per-year bikes if the plugs remain undisturbed for several years, or if the engine overheats even a little the plugs may stick in place and the threads may tear upon removal of the plugs. Anti-seize will prevent this. That is the upside.
    So you get to take your pick of which risk you are willing to take.
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Paul,
    Are plugs a torqued install on Airheads? I know on most automotive installations, they are a turned value, like 1/16 rotation or such depending on the seat type.
    When building a few auto engines, most torqued fasteners have values given using either a moly paste (ARP fasteners, ARP paste), or engine oil, with different values for the same fastener depending on which is used. I know on my Hexhead, the wheels are a dry install, with torque based on that.
    I like a small shmear of anti-sieze on my plugs, I've had plugs pull threads out of aluminum before, when not using it, so I do now.
    John.
    Fenwick, Ontario Canada
    44 years of riding motorcycles
    445,000 miles on my 1977 R100RS in 26 years
    I always use a dab of anit-seize on my plugs
    I Have never stripped a plug
    I have never used a torque wrench on plugs
    Common sence has to be used when installing plugs!
    Knights of the Roundel #333
    Registered User Air Race Addict's Avatar
    Aug 2010
    Cheney, WA
    I'm with you on this one. I work in Aviation and we use a small dab of anti-seize on all ignitors/spark plugs. Never stripped a plug hole. Ever. Just sayin. We do torque the ignitors, but that is taken into account by the manufacturer. I don't torque my spark plugs on my 78 R100RS. Had it since 86. Once again, it works for me so it's in the world of opinions and experience.
    Quote Originally Posted by DARRYL CAINEY View Post
