Results 1 to 11 of 11
Thread: gps question
    Registered User f14rio's Avatar
    mattituck new york
    gps question
    i just use the gps from my car on the bike when i need one.
    i just stick it on with a bit of velcro.
    thing is, i cant't hear the voice very well.
    it does not have an audio output plug.
    so this 65 year old low tech type of guy wants to know,
    is there a simple cheap way to get gps audio to a speaker in my helmet if i put one in there?
    not interested in music or phone. could do without a lot of wires also,
    thanks, goo
    "Enemy fighters at 2 o'clock!...Roger, What should i do until then?"
    2010 r1200r, 2009 harley crossbones, 2008 triumph/sidecar, 1970 norton commando 750
    Astatula, FL
    What model GPS?
    Bob Weis
    '04 K12RS - Hannigan Hack
    mattituck new york
    about like this
    but no blue tooth as far as i know
    http://g.factoryoutletstore.com/deta...uvi-265wt.html
    i guess that makes me wonder if a got another cheap gps with bluetooth how cheaply could i get away with a compatible helmet speaker?
    Sep 2008
    Wilmington, NC
    You can get older tech bluetooth setups like the Scala Q2 that I used to use for under $100 new. But you can probably find used stuff at $25. New "best technology" blueooth stuff is about 2X that. Scala G9, Sena, others....
    You've got to have either an audio out or bluetooth to hook up to your helmet and as you know some car cheapies have neither..
    BUT as an alternate thought- although I can connect my gps to my helmet I rarely use it that way. Found out from experience I prefer quiet except when exchanging info with my riding companion so prefer to just see the screen rather than hear it. Even when alone in my car I usually turn off the voice in that one.
    A feature I really like in newer Garmins is the lane change photos that now appear as split screen for complex urban interchanges, for example. Big improvement over the old map style. No more wrong lane choices.
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    Quote Originally Posted by f14rio View Post
    The new Sena SMH5 is about $97 at Revzilla.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    Astatula, FL
    Here's another option that may work for you. You will have to source speakers or earbuds.
    Bob Weis
    If it is a 265WT - you should have bluetooth already, at least the garmin website says it does. The big thing with bluetooth is that not all are equal. Before purchasing a bluetooth rig for your helmet, go to a bike shop and try the pairing procedure with a model you like to make sure the two are compatible. If you buy on line, many sources will say "you buy it, you own it" whether it works or not. (they are not liable for incompatible units.)
    Gear Up and Ride Safe
    Jim Rogers
    2010 R12GSA aka Heidi
    Yorktown, Va
    ExMaTprinLowerAlabama
    Nov 2009
    Gulf Shores, AL
    I bought a new Garmin "big screen" w/ bluetooth to do just that. HOWEVER, Garmin is cheaping out on us now by limiting the BT connectivity in many units. MANY will not connect to BT headsets... including mine! Be forewarned! On a positive side note, I just rode through a 200 mile rainstorms and this "car" GPS (NUVI 1490) performed flawlessly!!! (R1200RT mounted over dash) NO RAIN PROTECTION other than the windshield!
    Braintree, MA
    Quote Originally Posted by Herr_Eugen View Post
    Don't make a habit of it, you will damage the connector pins if they get wet. DAMHIK. Throw a plastic bag over it.
    -Tom (KA1TOX)
    Albuquerque, NM
    If your GPS doesn't have audio output, there's no way.
    Kent Christensen
    21482
    Braintree, MA
    Of course there is, you can always take a tap if there's a speaker.
    -Tom (KA1TOX)
