Results 1 to 9 of 9
Thread: adjusted toe in
    mattituck new york
    adjusted toe in
    (on my triumph sidecar rig). it tracks pretty well now at 65mph but in right turns the sidecar comes up too easily.
    i checked camber with a level (which is magnetic and attaches to the disc brake nicely) and noted i have to tweak that.
    right now, the bubble indicates 'lean in' which is exarcerbated when i sit on the bike.
    the bubble should be displaced to the left (lean out) which should help right turn stability.
    note: photo taken looking aft (front wheel, left side).
    the rig should be level (bubble centered) when fully loaded.
    i'm guessing this applies to beemer rigs also.
    Astatula, FL
    First make sure the surface you are parked on is level. Your camber adjustment will effect how the bike runs straight in regard to the crown of the road.
    Toe in will effect the push & pull of the car, and tire wear.
    The car lifting on right turns is the nature of the beast. Shift your weight, lean off, to the inside and maybe add some ballast to the car.
    Bob Weis
    '04 K12RS - Hannigan Hack
    www.earplugco.com
    mattituck new york
    10-q, bob
    i did check that the floor was level.
    Aug 2005
    Somers, NY
    when my wife got her first side car
    the previous owner showed her how to stand on the left footpeg and tug on the right handgrip, to see if the sidecar needs more ballast or not. Since the sidecar is a Velorex Jawa, it is light, and without a fair amount of sand bags, it comes up real easily.
    You might want to try that, before messing with the Toe in/out.
    Just my 2 cents......
    Somers, NY
    Just enjoying the ride.......
    mattituck new york
    i'll try that and letcha know what happens
    ntxt
    Arctic Art
    Oct 2010
    Manley Hot Springs Alaska
    You're messing with the wrong chicken.If the tracking is right the tow-in and lean are correct.Changing those will only throw things out of adjustment and increase tire wear.If the car comes up too readily add weight to the car and lean,get your butt off the seat to shift weight. Take some instruction and/or get a book.
    mattituck new york
    thanks, a hundred fortythousandeight
    there are at least 5 adjustments on my rig. the way to get famailiar with them is to screw with them and see what happens. then i'll write my own book.
    SW Ohio
    Quote Originally Posted by f14rio View Post
    there are at least 5 adjustments on my rig. the way to get famailiar with them is to screw with them and see what happpens. then i'll write my own book.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Arctic Art
    Oct 2010
    When I refered to a book I ment a "How to ride a sidecar" book.If the car is coming up you're not leaning enough,the car is too light or you're going too fast on the corners.This is not an adjustment issue.
