Results 1 to 9 of 9
Thread: Status Tag under Screen Name
    Retired Firefighter bmwgreenrt's Avatar
    Asheville, NC Ex-NJ
    How do I get rid of that "Junior Member" tag under my screen name?
    Jim
    IBA
    "What Would You Attempt To Do If You Knew You Could Not Fail ?"
    Focused kbasa's Avatar
    Re: Status Tag under Screen Name
    Good Question!
    Go to your User Control Panel using the blue buttons on the upper right. Select Edit Profile and go down to Custom User Text. You can enter your own text there and Junior Member will go away!
    Good Luck!
    Dave Swider
    Marin County, CA
    Loading the Bike NJBMWRT's Avatar
    NJ, USA
    Re: Re: Status Tag under Screen Name
    Originally posted by KBasa
    Good Question!
    Good Luck!
    This might be a moderator only setting, as I don't see that field. Of course it is still early and the venti caramel mochachino hasn't settled in yet...
    Re: Re: Re: Status Tag under Screen Name
    When you put enough messages up, it'll change to something else, though I forget what.
    Dave Swider
    Marin County, CA
    I believe you get that option after 10 posts. Until then, you get to keep this status:
    :newbie
    "No one wants advice -- only corroboration." -John Steinbeck
    Like San Jose BMW Motorcycles on Facebook.
    Asheville, NC Ex-NJ
    Thanks for all the feedback guys
    Jim
    IBA
    Asheville, NC Ex-NJ
    Thanks KBasa,
    You Rule!!!
    Jim
    IBA
    Thanks KBasa,
    You Rule!!!
    Glad to help you guys out.
    *starts talking like a commercial*
    And that, folks, is just one of the many reasons your Moderator and Admin Team are here to help -- you!
    *stops talking like a commercial*
    Dave Swider
    Marin County, CA
    Canada and the Alps
    Originally posted by KBasa Go to your User Control Panel using the blue buttons on the upper right. Select Edit Profile and go down to Custom User Text. You can enter your own text there and Junior Member will go away!
    Well the "Custom User Text" that you refer to doesn't show up...even after 10 posts as someone else stated.
    How did you change yours?
    I think the administrators have to change some settings. I'd like to decide on my own title. After all, this is a free world, isn't it.
