Results 1 to 8 of 8
Thread: 1979 R65 Headlight Assembly Questions.
    Sep 2011
    Orlando, FL
    I took the headlight assembly apart to see if the bulb's low beam filament (I guess it does have one) was burned out. When I did this, I noticed that there is a hole in the reflector portion for a smaller bulb. Is something supposed to go there? Also, the high beam works find but low is a no-go, and I changed the bulb with a new one (even though both filaments looked ok. Would this most likely be a switch issue, wiring issue, or some other thing?
    New Hampshire, USA
    The small hole in the reflector - if it is where I think it is - is for a small, ~4W bulb that is the "parking light" - that should be on when the keyswitch is in the proper position.
    BMWs in my garage: 1982 R65LS, 1978 R100/7
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    Have you got a wire with a receptacle for a small bulb laying loose inside of there?........Don't know if the R65 had that bulb......maybe a look at a parts fische will tell more?????????..............Maybe a schematic would disclose this also.......God bless......Dennis
    Pismo Beach, CA
    With thanks to MAXBMW's webpage
    Item #6 (above)
    You should have something similar to this /6 rig to hold the 4W "parking" bulb (the white circular shape under the main bulb)
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Albuquerque, NM
    As with ALL German vehicles ...
    yellow wire = low beam
    white wire = high beam
    brown wire = ground
    Kent Christensen
    21482
    Pismo Beach, CA
    And for your viewing pleasure, direct from MOA Resource Lists
    R65 Wiring Diagram
    Lew Morris
    1963 Dnepr
    Sep 2011
    Orlando, FL
    Quote Originally Posted by Lmo1131 View Post
    Item #6 (above)
    ah yes...this is missing. I read somewhere it might be Euro-spec only. I would like to get that working too, but I just can't seem to find the low beam issue. I'm guessing a circuit problem -- lots of corrosion :-/
    Sep 2011
    Orlando, FL
    R65 Wiring Diagram
    This is super cool!
