Results 1 to 15 of 29
Thread: k1600gtl Tire life
Hybrid View
    murfs79
    k1600gtl Tire life
    This will probably open a can of worms but what are people seeing on tire wear on this model? I understand Load and types of roads matter just trying to get a idea. I have 2k on mine so far in 3 weeks and going on a 2k trip and then a 1k trip and want to plan on tires if needed. I keep checking mine and after 2k I seem to be getting pretty good wear better than my LT but when they go down hill they go fast. thanks for your help
    No longer a member here
    I have 1200 miles on my GT now and I am already concerend about tire wear. It shows signs of the "typical" for Metzelers "trapezoidical" wear pattern that I experienced with this tire brand on my K1 and on my RT.
    Nov 2005
    Fairfax, VA
    If you have OE Metzlers, plan on a replacement -- there have been reports of rear cords showing in less that 5K miles.
    The Michelin PR3's I put on my GTL have 3.5K miles on them, and are not wearing nearly as quickly as the OE Z8's.
    Mark Neblett
    Fairfax, VA
    #32806
    Registered User Shaykon Qwinney's Avatar
    Oct 2006
    Alafreakinbama
    I had Z8's on my GT and I replaced the rear with a PR3 last week when the cords began to show after 5,500 miles.
    FWIW, I was aware of short life spans from the Z8's so I paid extra attention to tire pressures. Also, Im 300 lbs and put about 50/50 of interstate and twisty riding on the tires.
    Certifiable Old Fart beemerdons's Avatar
    Mar 2006
    Chandler, AZ
    Quote Originally Posted by mneblett View Post
    +1, Gunny; my OE Metzler Z8's were GONE at 5.5K miles, Michelin PR3's are looking good!
    Don Stanley; aka Chuy Medina "El Burrito Ballerina"
    BMWMOA #24810; www.azbeemers.org/forum #89
    Feb 2006
    I don't think the fast OE tire wear is a necessarily just because of the tire. I think when the owner quits playing with the bike, showing it off and exploring the performance, the tire life will improve.
    Fuse lit.... PittsDriver's Avatar
    Feb 2012
    Annapolis MD
    Quote Originally Posted by osbornk View Post
    You say "showing it off" and I say using it as the designer intended. If you're going to replace tires with inch plus wide wanker strips on them why buy a sport/touring bike? Just buy a touring bike. I didn't spend mid-20's for this bike to obsess over the life of a disposable item like tires and brake pads.
    Ride it hard, take good care of it, and replace stuff that needs replacing before it increases the risks of your riding, says I.
    Wes
    P.S. I put the PR3's on my K16GT and for a weekend in the twisties, I ran them down at 38 psi. With that configuration I used all but about the last millimeter of tire on the edges with rarely scraping anything but the toe of my riding boot. This bike has great ground clearance.
    -Walt 2wheelfamily's Avatar
    Jun 2006
    Sierra Vista, Arizona
    You're on to something. I ride with someone that chews through tires but he is very aggressive from the stop and very aggressive to the stop. He also dead-heads a lot on the interstate. All of these things drive him to the cords on his tires -- down the middle. This is what all tires do under these conditions...the difference is that the Z8s don't warn you before they go because of where the wear indicators are located. Just since posting my earlier email I put the new tires on and went for a ride. I kept it tame to scrub them but boy they feel good, but then this is to be expected when going from worn out to new. As an aside, I almost damaged my TPS not paying attention. So a word to those that work on their own bike, be careful. I never had an issue with my GSA (my only other experience with TPS) but I did with the GTL. I have no idea why.
    Jan 2011
    kentucky
    tire life
    I have 2011 r1200rt with 7600 miles on them, and need tires,and bmw calls the gtl and the rt touring bike,
    Jan 2014
    Jackson Springs, NC
    My Tires
    Original Metzler's made it to 7800 miles, with cords showing through on the rear tire. Put on a new set of Metzler's, but was leaving NC for Alaska in June and wanted something that "might" last the whole trip, or at least get me back to Seattle. Tried to get the Michelin PR 4, but it was back ordered. Went with the Bridgestone BattleAx. Had the rear changed in Anchorage with 8000 miles on it. Replaced the BattleAx with a Michelin PR 4. Maybe could have gotten another 1000 miles out of it, but that would have left me stranded somewhere on the Cassiar Highway. Had the front tire changed when I got back to Seattle with 11,000 miles on it. Also went with the Michelin PR 4. I now have almost 10,500 on the rear PR 4 and it still looks great. Front has almost 8000 on it and looking good.
    My choice - Michelin PR 4
    Mar 2012
    Lexington, IL
    My z-8's showed steel belts at 3475 and it appeared very rapidly < 140 miles. Michelin pr3's are working on 6k now and look to have 1-2k left in them.
    Fwiw
    Feb 2012
    Annapolis MD
    Quote Originally Posted by murfs79 View Post
    You didn't say which OEM tire your bike has and the experience has been different for the bikes rolling on 'stones vs. Metzlers. The Metzlers seem to be prone to cupping more so than the 'stones and they are designed in a manner that makes it a bit difficult to judge how much tire you've got left - particularly if your riding style wears them disproportionally in the middle. I've got 3,000 miles on my K16GT/Bridgestones and they've worn very evenly front and rear but I spend very little time on the slab and ride it like a sport bike. They've got a little life left but I'm going to swap them before a 1,500 mile ride I'll be taking a few weeks.
    In general, it's a very heavy, very powerful bike and that's going to be harder on the tires even if you're a granny that only rides it in Rain Mode to church on sundays. If you ride it hard, it's a tire eating machine.
    Registered User realworld51's Avatar
    Mar 2011
    Canton, MI USA
    Just replaced my OE Metzeler Z8s. With 7500 miles on them, they were worn and misshapen. They still had tread on them but I wasn't going to sweat the safety of continuing to run them. Replaced them with Bridgestone BT023 GTs for an excellent price.
    Steve W
    Canton, MI USA
    2012 K 1600 GT (from 8/6/2011)
    I have about 3,000 miles on my Metz's and I noticed today for the first time that when I am going straight down the road I catch some vibration through the bike. When I lean left or right the vibration goes away. Guess it must be the way the Metz's are wearing.
    Rick H.
    k1600 gtl tire life
    I had Z8 on mine 2,800 miles cords showing on the rear. The front is being replace this week end 3,800 mi. going on a trip next week. Replacing with PR3s.
    I hope they do better.
