Results 1 to 13 of 13
Thread: rake and trail
    Registered User f14rio's Avatar
    mattituck new york
    rake and trail
    so i'm leaving the baggage pick up at jfk with my wheeled luggage.
    rake
    when pushing the bag, noticed that directional stability was better with a lower angle but it was easier to maneuver with a higher angle. (cruiser vs off road?)
    trail
    when pulling the luggage, increasing the angle made for less directional stability (up to a point) but more maneuverability. while decreasing the angle improved it.
    i guess that's how motorcycles work also.
    anyway, that's the way my little pea brain works.
    "Enemy fighters at 2 o'clock!...Roger, What should i do until then?"
    2010 r1200r, 2009 harley crossbones, 2008 triumph/sidecar, 1970 norton commando 750
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    The handle on the luggage allows you to adjust rake, I'll buy that.
    But, trail is determined by how the line of the handle (extended) passes in front of the centre of the wheels. Not adjustable on my wheeled luggage.
    Glad my RT handles better than my luggage.
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
    No longer a member here
    Apr 2006
    Quote Originally Posted by BMW Triumphant View Post
    Indeed it is! When he raised or lowered the handle, the extended line from the handle hits the floor closer or further away from the wheels, thus changing the trail. Draw yourself a little sketch, it will make perfect sense.
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Oops! I was wrong...
    ...with my definition of trail. It is indeed measured along the ground, not at the centre of the wheel.
    Nice drawings in Wikipedia:
    http://en.wikipedia.org/wiki/Bicycle...geometry#Trail
    Ed
    Registered User arthurdent's Avatar
    Central Nebraska
    not rake and trail, but interesting, still
    When I take my office chair to the gym for PT conferences, I always watch the wheels. When pushing the chair, the wheels always go in a straight line. When I turn the seat around and pull the chair, the wheel assembly goes round and round like a ferris wheel.
    Best this physics teacher can come up with is that the forces while pushing are balanced, and while pulling, they are unbalanced. Probably doesn't have much to do with motorcycles, but interesting, nonetheless.
    Apr 2006
    Quote Originally Posted by arthurdent View Post
    The wheels on your chair should not know the difference between pushing and pulling the chair. If they are regular swivel wheels, they should turn and always roll straight on the floor with the contact patch BEHIND the point where the extended vertical axle would meet the ground. The reason they act different, is probably that you are putting a force to the backrest, which translates to a different reaction force at the wheels when pushed or pulled as the chair may tilt slightly.
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    TWhen I'm out in the yard getting rid of dead leaves, I always find the rake works best when you pull on it. But the RT works best when you push it. Must be that clever Telelever suspension, eh?
    p
    Pismo Beach, CA
    Experiments in Rake and Trail > http://www.tonyfoale.com/Articles/RakeEx/RakeEx.htm
    Experiments in raking a trail...
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    I was once trailed by a rake...
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    Quote Originally Posted by Pauls1150 View Post
    And...
    Doug, 2011 R1200RT Polar Metallic
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
    mattituck new york
    video on rake
    BugCollector
    I have found that my luggage is always faster and more maneuverable when I carry it with the handle. I can fly past or sometimes, through most of the other passengers. I am using red colored luggage. I think that is the fastest and maybe most assertive color.
    Apr 2008
    and... I told him I didn't roll that way.
