Results 1 to 15 of 17
Thread: Do BMW oil filters come with crush ring? ('12 r12r)
    Registered User mchad's Avatar
    Sep 2011
    White Plains, NY
    I just got a filter from Max BMW and was surprised to see that there was no crush ring in the box. I don't think I have ever bought an oil filter and had it not include one
    So before I get on them about it, I wanted to ask here.
    Sheboygan, WI
    Thumbs up
    No.
    However, my dealer (Nick's BMW) always tapes one onto the box as a courtesy - no extra charge.
    Sep 2011
    White Plains, NY
    Wow, i can't believe they don't. And it's supposed to be replaced every time isn't it. So I have to order a .05 part?
    Excellent.
    Thanks for the reply.
    Polarbear Polarbear's Avatar
    Clovis,CA
    Not unusual;
    Most filters I have ever bought do not come with washers, since my old Airhead days which did! Order? Most auto parts stores sell 'em cheap too. Its also not unheard of to reuse the washer once over, no foul. Randy
    Sep 2011
    White Plains, NY
    Quote Originally Posted by Polarbear View Post
    Well, I was actually thinking of BMW car filters. I'll check the local auto supply. Thanks.
    Nov 2007
    You can reuse a washer several times before it gets too thin or work-hardened.
    You can get at auto parts stores, sometimes in copper which I have mixed feelings. Copper can galvanic corrode, I do not know of any cases though.
    Rod
    Oct 2011
    Ohio
    I never replace the crush washer because I never loosen the plug. All I do is remove 2 of the screws on the filter cover, position the catch pan and then loosen the third screw. No fuss, no muss. I always clean the filter cover before reinstall so a little oil on the outside of it is not an issue. Plus I don't get hot oil on my hand as I try to remove the plug without dropping it in the catch pan.
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    Sep 2011
    White Plains, NY
    Quote Originally Posted by JeffD View Post
    Jeff
    I don't know if my R1200R even has a filter cover, as it uses a spin on. For the dime a crush ring will cost me, im not going to go unscrewing things I've never unscrewed. I might screw something else up...!
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Dunno about the 1200s, but when I get a filter for my 1150, there's always been a little baggie inside the box with an assortment of crush washers in it - engine drain plug, trans drain & fill, rear drain & fill.
    Are they now cheaping out with the 1200 consumables?
    Registered User pjjj3386's Avatar
    May 2011
    Campton, NH
    I've bought 2 filters from Max for my K100. They both came with 3 crush washers and an O ring.
    Maybe different for different models.
    Midnight Rider 41077's Avatar
    Jul 2004
    Gresham, Oregon
    My experience is you can get the filter or a filter kit. The Kit comes with washer, rubber
    O-ring (K75) most competent parts guys will ask if you want fries I mean washers with that.
    Northern Front Range, CO
    mod- how about we move this to Hexheads, which is were it really belongs.
    i've reused crush washers, but give them a bit of a bending (light finger pessure only) or an annealing first.
    no, your R does not a filtr cover, that's a K-bike thing. and i'm not sure that doing it JeffD's way gets all the old oil out of the sump.
    JeffD- how about you do an experiment for us? drain your normal way, but then before refilling, drop the drain plug and see what comes out. by then it will not be quite so hot, and any oil that comes out will not be real hot, nor will there be real much. but maybe a pint or so?
    Ride Safe, Ride Lots
    Clovis,CA
    Let it sit;
    Let the bike sit 20-30 minutes, then do the oil change. Oil is still plenty warm! I did it once on a hot engine, never again. K bikes still have spin ons, just under cover in sump. Probably the only bike engine in the world that way and BMW owns it. I got used to it on my KLT1200. I like my spin on GSA better, less work.Randy
    Sep 2006
    Some delaers "throw" the crush ring in at no apparent cost to you, others will sell you one. Have had it both ways on all models. I just keep about 3 dozen on hand for various uses on various bikes. I have reused one in a pinch, but it's rare.
    Oh yeah, moving to Hexheads which was the OP's model question.
    Steve Henson
    Mar 2008
    DeLand Florida
    My dealer usually throws them in without even me asking. However, they are cheap so why not replace them with every oil change.
    When I had my K100 I always questioned why they put a filter under a cover. Dumb idea until I remembered my 75 Moto Guzzi, the oil filter was spin on, but was inside the oil sump. You had to drop the pan to change it. Guess how many times it got changed.
