Results 1 to 3 of 3
Thread: hid xenon bulb
    hid xenon bulb
    just bought 2004 r1150 gsa and the bulb is out on the left side headlight- pulled the bulb and attached wiring and then found paperwork for "hid xenon motorcycle headlight conversion kit to suit bmw r 1150gs/adventure" so confident this is what it is went to nippynormans.com website but can't find bulb replacement HELP!! says pillips 9006
    Nov 2011
    Central Ohio
    A Philips 9006 is NOT an HID xenon. Perhaps the previous owner removed the HID kit before selling it? Can you trace the wiring to a HID ballast (black box) that is spliced into the factory wiring?
    Registered User Beemer01's Avatar
    Mar 2007
    Chicago, Ill
    So we need more information -
    Actual HID units will last about forever, so I wonder what burned out? There isn't so much a bulb in a real HID as a unit with wires that run back to a cigarette pack sized ballast that would be zip tied in place.
    If you don't have this, you have a Halogen bulb. If you do have this, replacing the entire thing is probably a $40 exercise. Try DDM Tuning.
