Results 1 to 8 of 8
Thread: Kisan Modulator
    ExMaTprinLowerAlabama
    Nov 2009
    Gulf Shores, AL
    Exclamation Kisan Modulator
    Well I bought the unit, install was easy/straightforward. Only one problem- no lights! Must be a bad unit... poor ground? ...and yes you CAN put the plug in upside down... but I didn't.. ...and yes I bought the BMW RT specific unit: P115W-A6-Z. I purchased it through spoiledbiker.com. I'll let you know how their customer service is...
    Sep 2008
    Wilmington, NC
    If that's the model that goes on the 6 wire connector at the rear of the headlamp housig...
    The connector on the Kisan is neither the same nor a spade size match to the factory one and may not be making a connection. Remove a rear lamp cover and reach inside the housing, putting some support on the rear of the bike connector, then push the Kisan on and see if it will work.
    You are not the first person to have a problem...
  3. 05-14-2012, 08:12 PM
    Reason
    served it's purpose
  4. #3
    Nov 2009
    Gulf Shores, AL
    The unit seats well and although it does not have a locking fitting it is a very deep and "tight" friction fit. When I turn the key on a get a very brief flash out of the parking lights, then nothing... No low beams, hi beam or parking lights... I have spoken to the folks at spoiled biker and I'm optimistic I'll have a replacement shortly...
  5. #4
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Quote Originally Posted by Herr_Eugen View Post
    Sounds like the CANBUS thinks there is a short circuit and quickly turns off the current.
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
  6. 05-15-2012, 02:59 AM
    Reason
    My post was for taillights, not headlight. Sorry
  7. #5
    May 2006
    Northern New Jersey
    I believe The OP's question is regarding the headlight, not the rear lights.
  8. #6
    You did start the bike, didn't you?
    The flash is normal at key on. You won't get full lights until you start the engine.
  9. #7
    Nov 2009
    Gulf Shores, AL
    I'm still "cautiously optimistic" but Kisan definitely uses email & voice mail to full advantage screening their calls...
  10. #8
    Nov 2009
    Gulf Shores, AL
    Well the replacement unit arrived today and alas it works fine! The first unit I had received was actually made in 2009. The new unit has a new secure fastener to plug into the "dash" socket. My only complaints are intermittent communication with Kisan... they call or email when they wish to, not to respond... and the mailer they provided for the defective unit was NOT postpaid. I'll survive, if it lasts now I'll be a happy customer...
