Results 1 to 9 of 9
Thread: 99 R1100GSMotor Exchange
    Registered User arptra's Avatar
    Feb 2006
    Dallas Texas
    I have a 99 GS with bad motor from oil site glass pop out. can anyone tell me if a 03 R1100S motor will fit?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by arptra View Post
    Call the guys at Beemer Boneyard, they will be able to answer.
    Ufda happens..........
    Pusser's Pyrate Society Zygmund's Avatar
    Oct 2008
    State of Hockey
    Don't forget to mention BMWMOA.
    '02 R1150RT
    . AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    I think the case and crank are the same. You'll run into incompatibilities in the top end (exhaust header attachment, for instance).
    Feb 2006
    Dallas Texas
    Gs motor
    Thx, yeah mike over at beemerboneyard said only gs/r/rs/rt will work, so if anyone runs across one with less than 32k please let me know.
    DUCMONZA
    Smile
    try LKQ. They often have a bunch of motors on eBay. I'm sure that if you contact them directly, they might be able to source one for you.
    Feb 2006
    Dallas Texas
    If I use a motor off an RT my exhaust wont work? Found an RT Motor
    Nov 2007
    The 1100 and 1150 are different. The exhaust header on the 1150 is a different shape and uses 3 studs not 2. Since the bore is different, I do not think 1100 heads fit 1150 easily.
    Feb 2006
    Dallas Texas
    Quote Originally Posted by ragtoplvr View Post
    I have a 99R1100GS and going back with R1100RT motor, unless I find a GS motor with low miles.
