Results 1 to 15 of 29
Thread: Carb(TB) Synchronizer
    Mar 2006
    I'm looking for a new carb synhcronizer. My old *MotionPro (mercury) stick has bit the dust.
    What do you recommend? I have a K75 and an r1100 gs.
    I see Motion pro does not user mercury anymore and Carb Tune uses stainless steel.
    Cheap and accurate is good.
    *I do have my old MP stick, some of the mercury had leaked out of it after I accidentally tipped it over. I was able to suction up the mercury and put it in a container. Is there anyway to salvage the stick? It still has some mercury in it.
    Andy
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    I would suggest you look at the Harmonizer. If you do a forum search you should pull up plenty. Just got done using mine, and I'm impressed again. (all over again)
    Ken
    -Albert Eienstein
    Polarbear Polarbear's Avatar
    Clovis,CA
    TwinMax:)
    I've got an early one of theirs and had it quite a few years now. Nothing better for my liking. I do all my bikes with it, from Airheads to my newer Hexhead. 3 holes as in K75, just alternate hookups, job done. The TM has only two hoses. I've done friends multiple cylinder(3+) bikes(Yamaha's,etc) with no issues up to 4 holes, doing the above. Its a tidy setup and lives in my saddlebags, whatever bike I happen to be riding, my TM is there on nearly every ride. NO, I don't need it hardly ever, but I LIKE knowing I have the means to adjust if ever needed and it takes so little room. I suggest disconnecting the battery, as mine has an on/off switch too easy to turn on, kills the TM battery. Easy battery thing to do and never need batteries again. My old TM takes a 9v...Randy
    Mar 2006
    harmonizer?
    thank you for the suggestions. I want to take a closer look at the Harmonizer but I can't find who sells it! I did many searches.
    Apr 2012
    HI Musicman:
    Previous Throttle Body Synchronizer thread can be found here:
    http://forums.bmwmoa.org/showthread.php?t=58770
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Quote Originally Posted by MusicMan View Post
    http://www.advrider.com/forums/showthread.php?t=701625
    Oct 2005
    NW PA
    Over the past 40+ years I have used vacuum gauges, manometers, Twinmax, my ears, and a Harmonizer. The Harmonizer is by far the best carb balancing tool I have ever used. Very easy to use, auto calibration at turn on with no recalibration required during use. Excellent display with a tach feature, that nothing else has, means you only have one thing to watch while making adjustments.
  8. 04-29-2012, 12:01 AM
  9. #8
    Nov 2005
    Fairfax, VA
    I've gone from mercury sticks, to a TwinMax, now to a Morgan CarbTune:
    http://www.carbtune.com/
    Stainless steel rods in the tubes; very sensitive/accurate. And no batteries to worry about being dead or corroding.
    Also has an available pouch (pretty cheap) which is well built, with separate compartments for the device, the hoses, and any adaptors you need (none of my bikes need adapter -- I just slide the hoses over the airhead/oilhead vacuum stubs).
    Mark Neblett
    Fairfax, VA
    #32806
  10. #9
    Jun 2011
    Piedmont area of NC.
    A friend and fellow member here has a Harmonizer, we used it to balance my R80 carburetors a couple weeks ago.
    All I can say is SWEET !!
    Easy to use, heck even i could probably do it by myself
  11. #10
    wz31857 wz31857's Avatar
    May 2012
    North Hills CA.
    tb synchronizer
    Harmonizer is what I use ,very simple,totally accurate.
  12. #11
    On the Road
    Mar 2012
    Tulsa, OK
    unisyn carb balance tool does an excellent job at balancing most any multiple carb setups. no special hoses or drilling holes needed.
    able to balance for low speed and high. very accurate results.
    best of all about $30 .. why pay more?
    you can pay more $$$ to achieve equal performance.
    but you cannot get better results than with a unisyn
  13. #12
    Jun 2008
    SF Bay Area
    When using your uni-syn are you pulling the air tubes off the throttle body of a fuel injected bike? Do you replace the air tubes as you move the device from side to side? Can you do that quickly with the fancy clamps used to hold the air tube to the throttle body?
    I prefer a device or method that lets me check with the entire air intake system in use... snorkel, air filter, air box, air intake tubes, etc. I don't know that it makes any difference, just feels right. I also prefer that my bike doesn't breath unfiltered air.
  14. #13
    On the Road
    Mar 2012
    Tulsa, OK
    unisyn is for carbs
  15. #14
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    Another Harmonizer +
    I'd been using the $4.00 balancer. Kind of a pain if the bike is very out of balance and you need a place to hang it. Tried out the TwinMax at a tech day and found that I kept hitting the calibration knob and having to start again, not for me. Read about the Harmonizer, ordered one and love it. Simple to use and the Tach feature is a real plus.
    Justin in Somerville, MA
    _________________________
    76 R75/6, 78 P200E, 63 VBB
    Lots of bicycles
  16. #15
    Jun 2012
    Syracuse, NY
    Tool suggestions
    Looks like the Harmonizer may no longer be available (see advrider link above) at least for quite a bit. Can any recommend the carb tune over the TwinMax? Thanks, Jesse
