Results 1 to 10 of 10
Thread: '02 R1150RT Gearbox Pressure
    Southbound gregh64's Avatar
    Milwaukee
    I changed the transmission fluid last weekend. When the fill plug was removed, there was pressure in the box.
    Any thoughts? I'm about to replace the breather (if I can get to it).
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    How much pressure? The breather will hold back a bit of pressure in either direction - this is to prevent ingress of water or dirt, it is designed that way.
    Ufda happens..........
    It's all about the details.
    Milwaukee
    GSAddict,
    Not known. Enough to give a good "whooosh" when I removed the fill plug. I'm concerned about the seals.
    . AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    Some of those breathers were made wrong; the little slot in them is not actually cut all the way through. It's easy enough to fix, so I wouldn't worry about replacing it. Just remove, clean and open the slot if needed.
    Anton Largiader 72724
    largiader.com bmwra.org
    Milwaukee
    Anton, Thanks. I'll try that this weekend and let you know what I find. Hope I can get to the breather quickly.
    '02 R1150RT
    Jul 2004
    Charlottesville, VA
    I just remembered I had a case where the gearbox seemed pressurized, but the breather in fact was clear and the box vented properly. I still don't know why it really seemed pressurized when I opened it.
    Milwaukee
    Found the breather...at least I could see it. No way I was going to get my hands on it without taking much more apart. I'll take it in to the shop after the Slimy Crud Run. Thanks for your valuable help and information!
    '02 R1150RT
    Milwaukee
    Anton,
    Just checked out your website. Very nicely done. Sure wish I lived closer. I'd roll it into your shop.
    '02 R1150RT
    Milwaukee
    Update:
    As of Sept. 2013, a new transmission breather was installed during a spline lube job. The original breather did not relieve. It had the "V" shaped indent in the inner tube, but it was not cut all the way. Could have cut the slit in it myself, but for $11.82 I installed a new one and kept the evidence as a conversation piece.
    Also doing new clutch and brake lines, since the rear brake flexible line was found to have a hairline leak.
    Much thanks to Anton, and also to Chris Harris at Affordable Beemer Services in N.H.
    '02 R1150RT
    On the Road
    Sep 2013
    Chris is the absolute best at what he does. We can all learn a lot from him. I wish he was a bit closer to Colorado.
    Sent from my iPhone
