2010 GS Rotors for Spare Wheel Set
banjuke
I just bought a set of spoked wheels for my 2010 GS and will keep the cast wheels. I used the rotors from the cast wheels on the new spoked wheels. Now I'd like to add rotors to the cast wheels so I can easily swap them for the spoked wheels. But I'm not having any luck finding rotors for my bike. Any suggestions as to what rotors would work? Thanks.
Pete
Part number 34 11 7 711 427 for the front rotors, 34 21 7 664 102 for the rear. If you pay for OEM equipment at the dealer the total will be about $1,000. Ay after market disc will be cheaper. I used the following from beemer boneyard when I replaced my rear. Much cheaper.
First of all ignore the fact the I mentioned the rear rotor... brain fade: forgot that is isn't part of the wheel. :doh
For the front you need the appropriate Torx bit (T40) and new mounting hardware.
