Results 16 to 21 of 21
Thread: What is "COLD" tire pressure?
    Sheboygan, WI
    Cool
    Quote Originally Posted by 40427 View Post
    AARRGH !!
    My head is going to explode !!
    Tire pressure recommendations sound like oil threads to me.
    What the heck are tire pressures supposed to be on an 85 a R80 with new technology tires ??
    I figure it's got to be different than 27 years ago , but how do you figure it out and get it right for the best long wear ???
    And I took a boatload of pot shots for a suggested 4-step oil change procedure?!
    Apparently, a government committee will need to be formed to look into this "cold tire' phenomenum - then lengthy Congressional hearings to get to the bottom of this!
    (Or, ..... you could just wait until tires are no longer hot from use and just check their air pressure.)
    #13338 PGlaves's Avatar
    Not really. By BMW specifications cold tire pressure is xx p.s.i. at 20 degrees celcius or 68 degrees fahrenheit. So if BMW says the cold pressure should be 36, then they mean at 20C. It would be higher at 22C or 25C and lower at 18C.
    I have a Smartire tire pressure monitor that displays actual pressure, internal tire air temperature, and a temperature correction shown as a + or -.
    When the specified amount of pressure and temperature are programmed in even if the tire is warm and the pressure increased the + or - 1 or 2 or 3 etc tells you whether the correct pressure is in the tire for the existing internal temperature.
    Registered User rkoreis's Avatar
    Orting, WA
    From the company website:
    SmarTire for Motorcycles
    SmarTire products are no longer available in the motorcycle market and the company has ceased support for this product category.
    Parts may be available at your local dealer, however, we retain no inventory to support service parts.
    Quote Originally Posted by rkoreis View Post
    Sure- mandatory on trucks and buses make that market more lucrative.
    But there are at least a half dozen other TPS makers out there. Not as good but better than tire kicking and the alarm function is very valuable. When a tire gets a little low they alarm!
    Sheboygan, WI
    Talking
    You're the first person I'd lobby to be on the Committee!
    cpannarbor
    A given amount of air in a tire will produce a different pressure reading at different temperatures. So a "recommended" pressure has two values: a pressure reading in pounds per square inch (p.s.i.) or in Bar, or some other standard; and, a temperature.
    BMW specifies recommended "cold" pressures at 20 degrees Celsius, which translates to 68 degrees Fahrenheit. BMW actually specifies pressures in Bar (1Bar = 14.56 p.s.i.) such as 2 Bar, or 2.1 Bar, or 2.2 Bar etc. Those specifications in Bar are converted to p.s.i. in U.S. publications.
    BMW specifies pressures to the nearest .1 Bar = 1.46 p.s.i so are actually less fussy that many riders tend to be.
    So the short answer is that to be precise, "cold pressure" ought to be at 68 degrees. When checking add a pound if it is a bit warmer and subtract a pound if it is a bit colder. You will likely wind up within 1/10th Bar.
    Owner's Manual of my '12 GSA says 68 degrees. I run 36F/38R. Don't ask me what kind of oil I use or how often I change it!
