Results 1 to 10 of 10
Thread: evaporative emission control system hose connections
    aapasquale
    Aug 2011
    Sag Harbor, New York
    I recently took all the fiberglass panels off my 1994 r1100rs which I just purchased to have them repainted. Of course, in order to remove the gas tank, the fuel and evaporative emission control lines had to be diconnected from the charcoal canister. In my mad dash to the finish line I failed to mark how the evaporative emission lines are to be reconnected. I have looked all over creation for a diagram or explanation, but so far have only discovered that I should have marked them first. This is not helpful......does anyone have a clue about this? Your help would be greatly appreciated.
    Tony
    aapasquale
    Aug 2011
    I recently took all the fiberglass panels off my 1994 r1100rs which I just purchased to have them repainted. Of course, in order to remove the gas tank, the evaporative emission control lines had to be diconnected from the charcoal canister. In my mad dash to the finish line I failed to mark how the evaporative emission lines are to be reconnected. I have looked all over creation for a diagram or explanation, but so far have only discovered that I should have marked them first. This is not helpful......does anyone have a clue about this? Your help would be greatly appreciated.
    Tony
    Clicky
    This is a removal procedure, however there is a diagram of the evap system that may be helpful.
    There are two hoses: the water drain from the filler neck and the internal vent. You should test them by blowing into them, but normally the drain line has X-X-X markings. That one gets connected to the line going to ground, while the other goes to the canister.
    When removing the tank, the easiest way to keep track of them (once you know they are right) is to leave one plastic connector on the tank and one on the bike.
    aapasquale
    Aug 2011
    thank you--I have a good idea what's to be done--the diagram was very helpful--Tony
    Albuquerque, NM
    The hose to the solenoid fits the center post. The solenoid is nearby. The other hose disappears so it can get to the fuel tank, and that's the side hose. If you have a "drain" hose it's to the nipple on the other end.
    Kent Christensen
    21482
    Mansfield,MA
    Hi guys, I merged up the 2 posts. Good luck. OM
    Mod Squad
    2009 F800GS 1994 TW200
    aapasquale
    Aug 2011
    bingo!
    thanks Kent
    that is exactly what I needed to know
    Tony
    Jun 2012
    Phoenix
    Helpful, But
    Could someone please post some photos of the exact routing from the solenoid purge valve back to the throttle bodies?
    My whole system has been removed and I want to route the hoses, the Tee correctly as original.
    Thanks, Ibjman
    Here you go. You can see that the canister hose runs outside the frame rail.
    The hose enters from the right and goes to the T behind the throttle body.
    This is on an 1150 but it's a better example than the 1100 I had available.
