Results 1 to 13 of 13
Thread: R100RT Fairing Removal Help
    Registered User rapz's Avatar
    Nov 2003
    Mission, TX
    I need to remove the fairing on my 1979 RT and wondered if the steps on "how to remove" are anywhere on the forum. I can't seem to find any. I'd like to know what to start with and how to progress in its removal. Thanks!
    Website: www.airheadmoto.com
    IBA No. 58411
    Current Bike 1979 BMW 100RT; 2013 BMW R1200RT 90th Anniversary Edition; 2008 Harley Davidson Ultra Classic 105th Anniversary Edition
    Administrator 20774's Avatar
    I think having something like this as a do-it-yourself might be good to develop. If you find something, post it here. Also, you might consider taking some good photos in a step-by-step documentation of the process. We could then turn it into a DIY for later use.
    Nov 2003
    Mission, TX
    Will do.
    IBA No. 58411
    Aug 2003
    Marion,Ar.
    The Clymer R-Series 70-94 work shop manual has a pretty good RT fairing removal/dissasembly section. Step by step with pics. Haynes manual is pretty skimpy on fairing removal.
    Friday Yet? 97077's Avatar
    Sep 2006
    Wis.
    I took an RT faring off a R80RT, first thing is I took gas tank off so not to ding that up. Windshield off then put that in a safe place. Took the 3 piece lowers off ( The lowers around headers have a space to take off without removing header pipe but I would take headers off and anti seize threads anyway. The upper faring will have to come off as one piece due to the rivets that hold the dash (dash is the part that holds volt meter and clock) and the storage areas. Then start with wiring that goes to turn signals and driving light ( driving light is the light bar above main head light). Make sure to remove glass and rubber part around headlight (4 screws under rubber part) due to those parts are getting harder to find. The glass and all turn signal lenses and clear light bar will have to be removed before removing fairing from brackets.
    Then there are 2 metal brackets that support the fairing, 1 is connected under gas tank and second is connected to the steering head ( be careful not to lose those bolts because if you put the fairing or a RS fairing back on those have to be the exact bolts due to their length)
    When I did my bike at first I thought the process would be a lot harder but once you get into it the project was quite fun and thanks to Mac for all his help. For me the hardest part was replacing the freshly painted RS fairing (thousand dollar paint job for all the fairing and saddle bags to match) Good luck and send me a message if I can help more. TAKE pictures. Kevin
    Nov 2003
    Mission, TX
    I finally did remove the fairing this morning and other than dealing with some fairly frozen bolts/screws it went okay. Let's see if I remember how to reinstall it!
    IBA No. 58411
    Registered User helmut_head's Avatar
    Feb 2011
    Michitucky
    Oh boy! I was hopped up on pain meds when I removed mine. After getting off the narcotics, and getting paint work done I was truly challenged by the reinstall process. But, it went fairly smooth after I thought through it.
    Keep that center/ upper clip together as one and things will be simple. The most difficult is putting the windscreen on. That requires imagination and patience because you'll never be able to see what you are doing and it's difficult to get your tools up there. Those little rubber peckers on the lower screen seal are also gonna mess with ya.
    When you put it back together, put the center clip on and put your gas tank in before you tighten the bracket to the steering post. You need to center the fairing on the gas tank. Lay rags between your fairing inners and tank to protect the tank paint. I'd recommend you get some of that plastic film and put it on the tank where your fairing inners/foam strip may touch it during service. You'll never see it and the film will protect your paint.
    Good luck!
    Helmut always wears a Helmet.
    Nov 2003
    Mission, TX
    Thanks for the hints.
    IBA No. 58411
    Registered User PeoriaMac's Avatar
    Aug 2003
    Washington, Illinois
    I bought my RT with the fairing removed. I'm getting to the place with the result of the bike --carbs, tank, etc, -- where assembly of the fairing is next. Please take photos and notes when you reinstall...'cause I know I'm going to need them.
    Mac
    Mac
    1986 R80RT, 2005 R1200GS
    Livin' Large On The Lake
    Nov 2003
    Mission, TX
    I'm taking my fairing to painter today so it'll be a week or so before I can get back to re-assembly. Will keep you posted.
    IBA No. 58411
    Aug 2003
    Marion,Ar.
    Reassembly of a newly fresh painted fairing is when the fun starts. Be sure to have a friend help to keep fresh painted pieces from being scaped.
    www.hivizstore.com hivizguy's Avatar
    Feb 2008
    Pittsburgh Area
    giving it a go
    since acquiring my RT, i've never felt comfy with the full fairing. seeing this pic on the BMW website got me motivated. thanks for the thread. see you in Hamburg NY this Summer.
    Be Seen and Be Safe
    Albuquerque, NM
    Quote Originally Posted by 97077 View Post
    You'll also want to remove the ignition switch from the fairing ... which will prove very much simpler (and safer) than removing the wiring from the switch.
    You will have to remove the wiring from the gauges, however, and if you can get the wiring off the turn signals and park light you don't really have to remove these from the fairing in order to get the fairing off the bike. You will like the access removing the park light provides for getting the nylok nuts off the windshield mount, however.
    Possibly someone can do it, but I think the likelihood of being able to reuse the windshield-to-fairing gasket after removing the windshield is about nil. Bet you destroy the gasket when removing the windshield. New gasket means separating the dash and fairing and installing new rivets. VERY nice to have the official rivet tool.
    Kent Christensen
    21482
