Results 1 to 13 of 13
Thread: Help with a gripe about my grips
Hybrid View
    Does anyone know if a grip sleeve (to make the grips more robust/larger) will affect the heat that emits from the OEM heated grips? Im experiencing some fatigue and cramping that I think is due to the small diameter grips that came on the K bike that I just purchased. Im assuming that this will eliminate the problem because I do not experience this with my other bikes.
    Geeser mcover's Avatar
    Nov 2006
    Annapolis MD
    i have these
    http://www.originalbeemerbuddies.com/
    they do not interfere with the heated grips at all.
    Marty
    K1600GTL
    F700GS
    IBA #42016
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    I run Grip Puppies on my RT. No problems at all with heated grips. Just take a little onger to warm through - just like wearing thicker gloves.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Braintree, MA
    +1 on Grip Puppies -- will solve all your grip gripes!
    -Tom (KA1TOX)
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Grip Puppies didn't work for me. But this bag of o-rings did:
    http://www.excelcyclewerkes.com/inde...s/Page1340.htm
    David Brick
    Santa Cruz CA
    2007 R1200R
    Clovis, NM
    So yer saying he can come to grips with his grips?
    I'm good with that......
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
    Astatula, FL
    Quote Originally Posted by mcover View Post
    i have these
    +1 on these, look good, feel good and don't restrict the heat.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Registered User LSkrabut's Avatar
    Jul 2008
    Spanish Fork, Utah
    I used these from Beemerbone yard for years and with stock heated grips. I like them a lot. On sale for $5.95 a set.
    http://www.beemerboneyard.com/foamgripcov.html
    They tended to wear out in a year's time or so, depending on how much you ride or left in the sun. I never felt that the heat from the grip was diminished. Hands were always plenty warm considering the temps I was in and glove that I was wearing. Note there is a minimum order so I usually got 2 or 3 sets per order. Shame they are out of stock at the moment.
    I have since switch to an aftermarket grip and do not need the extra diameter on the grip any more.
    Larry S
    Utah driven
    2003 K1200RS
    1988 K100 LT
    Mar 2011
    socal
    Tired the bag of o-rings, didn't like them no problem with heated grips just took longer to warm up
    Local dealer had grip puppies, like them a lot again no issues with heated grips, think after a year are so may need replacing,..
    Grampa Tumbleweed
    Union Grove, WI
    Grip Sleeves
    I've got neoprene grip wraps on my R12RT, there may be a delay in the heat but I still get enough heat that after a while I usualy need to turn them down from #2 to #1.
    + another for beemerbuddies
    I have had excellent service from the beemerbuddies guy; I like the bb's and yes,the heat does come thru very well; might take a minute or 2 longer to get to your hands, but the heat is just as strong; then the heat may last a bit longer after you shut the switch off. The bb's are on both BMWs and they are adjustable and removable if necessary. I have no problem buying another couple of pairs in the future.
    -pp Long Distance Motorcycle Adventurer
    '00 GS w/ >180K miles/for sale; '07 RT 160K miles/sold; '12 K1600 GT 20k miles/totaled;
    '16 K1600 GT 15k miles
    LD blog: www.ppldma.com
    Registered User ezec's Avatar
    Aug 2011
    Arkansas
    I would agree with beemerbuddies. Good product, service and no complaints. Heat up faster than my foam set they replaced.
    2010 R1200RT
    GO HOGS!
    Mar 2012
    Lexington, IL
    Beemerbuddies are good for me through this winter. Can't beat the customer service either.
