Results 1 to 15 of 18
Thread: Zipper problems on riding jacket help
    Registered User bmwgsrider's Avatar
    Amarillo, TX
    I have has my Olympia riding jacket since May 06'. All of a sudden, I am having problems getting the jacket to zip. It's either like playing tugowar and not sure if you will win or the jacket. I am having problems zipping the jacket up and just not only on my person but with it off too.
    Does anyone who have has problems not being able to zip jacket have any words of wisdom on what I can do to where I don't have this problems to where it will start Zipping nice again.
    It's still a very good riding jacket and in good condition.
    Thanks in advance.
    Bye bye 2006 F650 GS for a 2011 F650 GS.
    On the Road fireguy's Avatar
    Oct 2010
    Federal Way, WA
    Try cleaning the zipper teeth and slider with an old tooth brush to remove dirt, etc. Then rub a bar of soap up and down the teeth an inch or two to lube. I've done this on my work boot zippers and have had some luck.
    Good luck. gm
  3. 03-03-2012, 05:36 AM
  4. #3
    Registered User clowry's Avatar
    Sep 2006
    Oakville, ON
    If all else fails, you could probably have the zipper replaced reasonably enough. Some dry cleaners offer alteration/repair services, or one of those Stitch-It type places.
  5. #4
    Clovis, NM
    Wax.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
  6. #5
    Jul 2008
    Central PA
    Quote Originally Posted by bmwgsrider View Post
    Thanks in advance.
    Make sure you don't have a fabric caught under the zipper slider. I have an Eddie Bauer fleece jacket with a poorly placed flap/cover near the zipper. If the flap is caught under the slider........it's a real bear to un-jam
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
  7. #6
    Blue Sky Canadian
    Trail, B.C. Canada
    Zipper Malfunction
    Had something similar with my Airflow jacket a number of years ago. Took it in to have a new zipper installed and the guy reached under the counter, grabbed a set of needle nose pliers, tweeked the zipper head twice and voila! He says he does this all the time and he has never replaced a malfuntioning zipper unless the whole thing has split apart. Worth a try before you pay to replace a zipper. Good Luck.
  8. #7
    Astatula, FL
    Quote Originally Posted by K1300GTGlenn View Post
    From the website of some guy that used to repair tankbags.
    Here is your chance to "do it yourself" following these simple directions. First it is important to clean and lubricate your tankbag zippers. They are full of the road grime that you routinely wash off of your bike. I use a silicon spray, apply liberally, wipe zipper with a clean rag, reapply and operate the slide. What a difference!
    You should also be aware that most, but not all BMW tankbags use locking tab zippers. To release the lock you pull out on the pull tab, perpendicular from the direction of the slide travel.
    If you have a zipper that seperates after being closed, you can often repair this by squeezing the slide together with a pair of pliers. You want to squeeze it just slightly, not to the point that the slide binds on the cloth portion of the zipper.
    Note: This method works on any zipper that is not too worn, including jackets, pants and Stitches. Lube your tent zippers too, nothing worse than a 2AM nature call and being unable to get out!
    Bob Weis
    '04 K12RS - Hannigan Hack
  9. #8
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    Slider Issues
    If cleaning and lubing the teeth doesn't work, your problem may be the slider. I had this problem with my TourMaster jacket and a non-MC rain jacket. I replaced the sliders and all was good again. TourMaster sent me new sliders gratis even though I'm the second owner (Kudos!). There are zipper specialist where I live, there may be some in your are as well. They should have parts as well as entire zippers if an entire replacement isn't warranted.
    Justin in Somerville, MA
    _________________________
    76 R75/6, 78 P200E, 63 VBB
    Lots of bicycles
  10. #9
    Jul 2005
    Colorado
    Had the same problem with an Olympia jacket.... Called them and they sent me a new zipper that I had a local tailor install. Things wear out after awhile.
    Greg
  11. #10
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    Not an expert here, just a fellow sufferer. Take my comments for what they are worth.
    1. On NON-faulty zippers cleaning and lubricating can prevent problems and make them work much easier. I lean toward silicone spray on a rag rather than wax or soap. Seems to me the latter two items are more likely to accumulate dirt than silicone.
    2. BEWARE of really fine-toothed zippers. (I'm thinking of the one on my Fieldsheer rain jacket.) Put any stress on them and, when they separate, I think the damage is done. No amount of tinkering has fixed mine - though there is always the possibility my tinkering was less than expert. Will look into getting the zipper replaced, though the jacket also has velcro tabs that overlap the zipper and work fairly well.
    3. I have an old BMW tank bag on my K100RS - slightly modified locally to fit since it came with the dear departed K75. One real PIA was unzipping the bag to fill the gas tank. Go one notch too far and, instead of being able to hinge it up, it was unzipped from the base. Getting it back on the base required removing the whole damn thing, several minutes, and language I'm not proud of. The solution to THAT problem was a couple bobbypins through the fabric just short of the un-zip point.
    4. I've had a somewhat unsatisfactory relationship with zippers since age 5 when I caught my scrotum in my pants zipper. I'm now 65 and, with therapy, am making some progress.
    Doug
    1992 K100RS
  12. #11
    On the Road
    Feb 2012
    Shaw Missouri /Boone County
    I somehow cought my jacket zipper in the closet door. Lotsa leaverage there.
    The narrow end was pinched, and out of alignment, had to strighten it with plyers. Was maybe .005in or so.
    Probably would not bend much further without breaking.
    I figgured if I broke it, it was off to the taylor anyway. Was a nylon "wear guard" from my work.
  13. #12
    Oct 2010
    Federal Way, WA
    The reason for using a bar of soap is that it is easy to wash out to remove the dirt that any lube will attract. it's always available, and it won't stain the fabric. Also, it won't melt like wax does.
  14. #13
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    Quote Originally Posted by BCKRIDER View Post
    I also use silicone spray. It worked for me.
    Harry
  15. #14
    On the Road
    Jan 2012
    Tucson/Haines, AK
    If it is an up/down zipper have it replaced with an up only. I have had more trouble getting the up/down to start over the years and now I just have them changed out when I buy the jacket. Cost about $25.00 at my dry cleaner's tailor.
  16. #15
    Jul 2007
    THE BIG SKY
    Inspect the zipper very carefully to see if there is something causing the problem... I mean with a magnifying glass careful. A thread or similar item can cause the issue. Check to see if the slide has an equal gap on either side and that the gaps are sufficient in size to allow the device to slide.. A bump can pinch one or both sides and make the thing difficult to use. And lubricate. Several workable ideas above; I like a little carefully applied silicone.
    If all else fails take it to a taior to inspect; he/she will know what to look for.
    Good luck.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
