Page 14 of 14 FirstFirst ... 4 12 13 14
Results 196 to 201 of 201
Thread: Another one of those rebuild stories R50/5
  1. #196
    Nov 2005
    Calgary, Alberta
    That's a lovely, bright, room, made even nicer with a bit of industrial art.
    Rinty
  2. #197
    So I'm getting copious amounts of white smoke coming out of the pipes upon initial crank and turn over. Then, when I give the engine some revs, it slowly dies down. The smoke is inconsistent as it will almost always appear on a cold start and only sometimes appear on a warm crank. As a whole the bike is running great.
    Any suggestions for trouble shooting would be appreciated.
    BTW, after spending $200 for the ignition timing to be tweaked by the dealer, I learned how to do it myself when I installed new points. It took a while to wrap my head around gapping the points then whether it needed retarding or advancing but I finally got it.
  3. #198
    Cool
    Awesome job on a beautiful bike! I need something like this to play with. :-)
  4. #199
    Aug 2006
    Scranton, Pa.
    Great project!!!
    Great story. Many good miles to you and your mistress
    Regards,
    Will
  5. #200
    Registered User R100RTurbo's Avatar
    Jun 2013
    Abbotsford, BC Canada
    Quote Originally Posted by barrettnjones View Post
    Not sure you worked out your white smoke scenario, and how many miles you have put on the engine to seat rings (I read your entire story but don't remember how your cylinder bores were treated). Many will have vast knowledge I'm sure on this subject here, but it can be oil based smoke, if you also note a haze on decal that almost clinches it. I've found intake valve guide to stem clearance can be a factor for this.
    Your project sure turned out nicely, hope you enjoy it as much as it looks good.
    Lorne.
  6. #201
    Registered User donmitt's Avatar
    Mar 2006
    Bellville, TX
    I Don't know if anyone told you about bmw twins will sometimes smoke if parked on the side stand over night. I enjoyed your journey with the restoration.
    Ride safe and often.
    Don
    Don Mitchell
