Page 3 of 14 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 31 to 45 of 201
Thread: Another one of those rebuild stories R50/5
  1. #31
    Jun 2008
    The steering assembly and front end came out pretty easily. As mentioned before the forks got new springs and seals right before it was sold to me so I won't be doing anything there except for checking the brake and cleaning it up a bit.
    Question: Just after dropping the shocks down I realized I didn't make the location of the lower fork cross brace on each shock. Any good ideas as to know how far to slide the fork back up or is it a moot question because as long as the shocks are in the same position it doesn't quite matter.
    Here's a pice of it all off the frame except for some small things here and there.
    Almost ready for the sandblaster!!
  2. #32
    Jun 2008
    Dreaming of SPRING!! can't wait for the assembly process!
  3. #33
    Jun 2008
    Finally got the driveshaft pressed out of the swing arm. What a crazy thing that was. My buddy has a half ton press in his barn. He was happy to help but it was about 16 degrees out there. After a few tries and a realization that we're just not applying enough force it finally popped out. I think I lost a finger or two to frostbite.
    When it's time, how in the hell am I going to get that shaft pressed back together with the clutch bell housing!!!!
  4. #34
    Jun 2008
    A little steel wool, Mother's, elbow grease, and BAM!! New lens covers, gaskets, and bolts too.
  5. #35
    Jun 2008
    Clutch stuff.
  6. #36
    Jun 2008
    How do I know if any clutch parts need replacing?
    Before tear down the clutch was super grabby.
  7. #37
    Jun 2008
    Here's an album I've created from some pictures of my own bike but mostly images I've pulled off the web. I'm using this set of pictures as a source of inspiration.
    http://gallery.me.com/barrettnjones#...lack&view=grid
  8. #38
    Aug 2003
    Marion,Ar.
    I know what your goin thru. I have my '74 R90/6 apart for a total rehab. Engine out of bike and mostly built. Endless projects ahead to push it forward to completion. This afternoon I will ride my '71 R50/5, which is also my first bike, as a tribute to both you and me. Just keep plugging away; we'll get ur done.
  9. #39
    Nov 2005
    Calgary, Alberta
    Great thread; thanks for posting.
    You must be putting in a lot of hours, having two new "projects" going at the same time.
    Rinty
  10. #40
    Jun 2008
    Flywheel removal. Notice those pistons have been removed as well.
  11. #41
    Jun 2008
    Blah!!
    Check out the oil cocktail that's been spun around the clutch housing. Time for a new rear main seal.
  12. #42
    mymindsok
    Quote Originally Posted by barrettnjones View Post
    Blah!!
    If you're smart, you'll replace the oil pump seal wile you're in there.
    Just sayin....
  13. #43
    Registered User PHMARVIN's Avatar
    El Paso, TX
    Hi, Barrettnjones,
    Now that you've already removed the flywheel, I hope you first blocked the crank so it can't move forward
    Ride Safe,
    Phil Marvin - El Paso, TX
    '94 K75A/3
    '95 K75RTP
  14. #44
    Jun 2008
    Quote Originally Posted by PHMarvin View Post
    Hi, Barrettnjones,
    Yes, I've blocked the crank with the front cover. And yes I will be replacing the oil pump cover with a new one that can hold hex heads. Thanks guys!!
    Please check out my Rear Main Seal thread as that's what I'm having a question about currently. There was a thin metal disk behind the rear main seal and I'm not sure what it does or if it's needed. Maybe it helped set the depth of the out seal?? And it's not needed with the new ones? I'd just like to be sure before moving forward. Check it out, there are more pictures.
  15. #45
    Jun 2008
    https://www.icloud.com/journal/#p=01....jb/index.json
    No thread is complete without a big'o bowl of eye candy. Although this photo journal of bike porn isn't exclusively BMW I think you'll appreciate the exceptions.
