Results 1 to 15 of 30
Thread: Throttle Body Synchronizer
    Registered User 39520's Avatar
    Jul 2003
    isola di specchio
    Hi: anyone care to recommend, from experience, a good TBS? I'm going to use it on my K12S.
    Thanks!
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    I would recommend the new "harmonizer".
    much easier to use.
    Ken
    -Albert Eienstein
    They call me Gort scootrp125x's Avatar
    Sep 2004
    Argyle Texas
    I own and use a Twin Max. I bought a Harmonizer a couple of months ago but haven't had time to try it out and compare the two.
    04 R1150RT
    Registered User David13's Avatar
    Nov 2011
    Lomita, California
    I have the Harmonizer. Simple, easy to use, really a nice device.
    There have been those who say it is, or cannot be as accurate as the fluid type system.
    I do not believe that. The modern computer type systems are far more accurate than the old manual systems on cars and motorcycles.
    And I suspect with a device like this, it is actually more accurate.
    I have heard anecdotal accounts of it being tried at BMW dealers, and they found it was just as accurate as their systems.
    Check advrider for Grok and his Harmonizer.
    dc
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    I too, have the Harmonizer. Just got is a couple of weeks ago and haven't used it in anger yet, but did fiddle with it. I'm swapping the front tire this weekend so since I'll be playing mechanic then I'll go ahead and try syncing the TB with it.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    I've never done a TBS on a K bike.
    Lee
    2016 R1200RS
    MOA # 30878
    Pismo Beach, CA
    Harmonizer here. +1
    Really versatile tool, and it has a built in tach (and you can signal helicopters with it (really)).
    http://advrider.com/forums/showthread.php?t=692535
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    May 2007
    Raleigh, NC
    I use a Twin Max, works great. But the Harmonizer looks cool. I'd likely buy that over the Twin Max if I didn't have a tool already. But, the argument that the liquid tools are better than the digital tools doesn't hold water for me. If it is true that they are more accurate, then in my opinion, that higher degree of accuracy is not needed because I'm always pleased with the results on my RT and /6.
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    My thoughts
    I started with the $4.00 synchronizer, which worked well, but one needs to be careful if the carbs are way out of balance or the fluid will be sucked into the engine. You also need a good place to hang the thing.
    I tried the Twinmax at a tech day and found the ergonomics wanting. I kept hitting the zero knob and having to re-calibrate. I've spoken to others with the same complaint.
    I picked up a Harmonizer at the intro price and have been happy so far. Self-zeros, no controls to bump, easy to read and I'm able to locate the box where I can see it while lying under the bike to reach the carb screws.
    Justin in Somerville, MA
    _________________________
    76 R75/6, 78 P200E, 63 VBB
    Lots of bicycles
    May 2007
    Raleigh, NC
    Quote Originally Posted by stanley83 View Post
    I've done that! Fortunately, it only takes a second to re zero. But again, just looking, the harmonizer looks very cool Anyone want a used Twin Max at a 50% discount so I can buy the Harmonizer? I like new toys!
    '10 R12RT, R90/6
    Suzuki DR 350
    May 2003
    SW Iowa
    The OP has a K1200S (4 cyl)
    Someone correct me if I'm wrong, but you don't need to do a throttle body synch on a 4 cyl. K bike.
    We've put close to 500,000 miles on K bikes and none of them have ever needed a throttle body synch.
    Lee
    2016 R1200RS
    MOA # 30878
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    I use a MotionPro SyncPro:
    http://www.ebay.com/itm/MOTION-PRO-S...9#ht_557wt_689
    It's for up to 4cyl. Easy to use.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    May 2003
    SW Iowa
    I found an old thread on the subject at I-BMW.
    http://www.i-bmw.com/showthread.php?...tle+body+synch
    Lee
    2016 R1200RS
    MOA # 30878
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    That thread contains some VERY bad suggestions and info!
    NEVER, NEVER, NEVER touch or adjust the linkage between the throttle bodies!!!!!!!!!
    A throttle body adjustment on a Kbike involves ONLY adjusting the large brass air bleed screws on each throttle bore.
    NEVER attempt to adjust the butterflies, just adjust the air bypass screws.
    This primarily affects idle smoothness. Messing with the butterflies WILL screw it up over the entire range.
    Mine, Hers, Spare
    May 2003
    SW Iowa
    I need to go back and read all of it again, I didn't see where someone said to adjust the linkage.
    What I got out of it, was because of the mechanical linkage, the throttle bodies stayed in sync, unlike the boxer engine.
    To me, posts 5 and 6 in the link are good points.
    Lee
    2016 R1200RS
    MOA # 30878
