Results 1 to 15 of 46
Thread: Pictorial--2002 1150RT Spline lube
    May 2008
    Adirondaks and LI,NY
    I've just finished lubing the splines on my 1150RT and I'll post 5 or so pics per day illustrating the same to help anyone out there wanting to pursue this endeavor. I'm assuming that you have already removed the tupperware from the bike and secured the front wheel to your centerstand. Also document the wire runs from every angle if you can because you will want to route everything as it was with the exception of the shift indicator wire and connector. You'll hear more on that below. There are other procedures I used by Awagnon, a member here that provides a great procedural and Grant at ADVRIDER who provides another pictorial on his GS. Powerman also provides a written procedural which I used, all found here:
    Awagnon's procedural:
    http://dl.dropbox.com/u/35468239/Spl...%2026%2011.doc
    Grants pictorial:
    http://advrider.com/forums/showthrea...ighlight=Grant
    Powermans procedural:
    http://kueglers.org/Powermans%20Spli...0Procedure.pdf
    Also, this link may assist you in disassembling the gear shift indicator connector so that it will pass easily through the tight space under the battery tray. This has been referred to as the most difficult and time consuming task of removing the transmission. Go to this link, and refer to page 10.
    http://www.rbracing-rsr.com/download...connectors.pdf
    May 2008
    Documenting wiring etc.
    May 2008
    Day one
    May 2008
    Separating the radio from the tank up forward.
    May 2008
    Removing the rear radio securing hardware.
    May 2008
    Don't forget the little nub back here that holds the radio in the box.
    May 2008
    Support the radio.
    May 2008
    Air tube to be removed
    May 2008
    Removed air filter, battery next, disconnect the Neg lead first.
    May 2008
    I won't post all the photos I have but you should document the wire and tube runs around the entire bike, you'll need them later!
    May 2008
    Brake needs to be disconnected to remove foot peg side panels.
    May 2008
    O2 sensor connector, attached to silencer or exhaust system
    May 2008
    Right side foot peg panel. BMW Ken, another member here sent me a PM suggesting removing the rear brake indicator switch from the panel, that would have been easier than unrouting and removing the tie wraps as I did. Please, others that have done this and have suggestions that make this job easier or streamlined, feel free to add or subtract from this.
    May 2008
    Follow wires back and cut tie wraps. Make sure you document wire runs etc. I'm not including all that here to keep the downloads to a min.
    May 2008
    Run the brake switch wire down the gap that the shock adjuster tube runs. It provides enough space to get the connector through and off the bike.
