Results 1 to 8 of 8
Thread: u-joint inspection
    Aug 2006
    Lawrence, KS
    u-joint inspection
    Bike: 1978 R100S. I've been checking and reassembling a project bike. I noted a slight knock from the drive train while turning the rear tire by hand or rolling the bike around in the garage. It's a much louder knock while under power and riding slowly.
    I disassembled the rear drive train up to the tranny. The rear drive and transmission both turn easily and smoothly by hand. The u-joint however seems to have a bit of "notchiness" on one axis. Is this normal or possibly the source of my knock? Any thoughts would be appreciated.
    John Kuhn MOA#83073
    R1100S, R100S, Honda VFR
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    U-joints are not supposed to knock. Sounds like time for a new driveshaft, or you'll need to remove the old one and get it refurb'd.
    F.O.G.Rider, Rounder #6,
    Ambassador
    BMWRA Wisconsin Region Rep
    MOA Biergarten co-chair
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    If there is any sideways or up and down play in the u joint then it is toast. Sounds like you may need a new one.
    One thing to check is that there is proper clearance for the driveshaft too work up & down. A lot of times people get so intent on centering the swingarm they forget to allow a bit of room for the U joint to work properly. Check and see that it is not the driveshaft hitting the tube. If it is a clearance issue you may have to adjust the swingarm by moving it a little to the left or right to fix this problem.
    1971 R50/5 SWB with R75/6 drivetrain
    2013 DL650
    Aug 2006
    Lawrence, KS
    Excellent advice. If I adjust the swing arm slightly to the left the knock goes away. The u-joint was rubbing the inside of the swing arm bell opening. Thanks!
    John Kuhn MOA#83073
    Northern Front Range, CO
    what happened with that notchy u-joint you felt? not notchy, or are you planning to ignore it until it blows apart?
    Ride Safe, Ride Lots
    Aug 2006
    Lawrence, KS
    I sent an email inquiry to Ted Porter to see if they rebuild twin shock airhead u-joints. (They don't as they rarely need it) Ted advises a slight notch in the middle of the u-joints travel range as normal. That's what I have. There is no axial or rotational play. So I'm going to go with it.
    John Kuhn MOA#83073
    gotcha.
    for those in need of a shaft rebuild.. http://www.machineservice.com/
    less costly than Bruno's, and no border issues to deal with.
    Pismo Beach, CA
    Or, as recommended by Ted Porter: Henderson Precision, in Big Oak Flat, California.
    Lew Morris
    1973 R75/5 - original owner
