Results 1 to 2 of 2
Thread: Sena SMH-A0302 connector question
    I purchased a Sena system but would like to use a wired mic with it instead of the boom mic with my modular helmet. I must have a chin like Leno because there just doesn‘«÷t seem to be enough space for the boom mic between my chin/mouth and the chin bar. The Sena A0302 Helmet Clamp Kit has an option to use a wired mic (or an attachable boom mic) but I would like to add a little more length to the mic wire to provide plenty of slack when the chin bar is opened and closed. There is a connector between the Sena helmet clamp on the side of the helmet and the mic where I could patch in a 4-6 inch extension easily ‘«™ if I could match the connectors.
    I was wondering if someone with some knowledge or experience with small connectors has an idea where I might find a connector like this. The connectors are about ?? inch wide. I checked with Sena and they didn‘«÷t sell any premade extensions or connectors which would allow me to fabricate my own extension. I gave some thought to just trying to splice in some extra 2 conductor wire but the existing wire is pretty small.
    Has anyone seen any sources for similar connectors? I would certainly entertain anyone else‘«÷s experience addressing this same issue with the Sena system or any realistic (and physically possible) suggestions.
    http://i853.photobucket.com/albums/a...SenaA03020.jpg
    http://i853.photobucket.com/albums/a...ped314x235.jpg
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    I saw one setup where the guy used the small mic and attached it to the front side of the cheek pad on his flip up helmet.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
