Results 1 to 7 of 7
Thread: side stand ??
    Jun 2011
    Piedmont area of NC.
    side stand ??
    I was giving my 1985 R80 a bath today , suddenly the side stand spring comes off along with some kind of a plastic bushing that looks like it might be part of the return spring retention ??
    I have a Farley stand mounted and never use the OEM stand anymore anyway. So i thought i would just remove it.
    And then the fun began !!
    I took off the main nut but did not remove the crash bar, so i was not able to get the OEM stand off ??
    How the heck does it come off ??
    I managed to get the spring back on , but not with the bushing , there was only one anyway so i was not sure which end of the spring it should go into.
    I used two plastic zip ties to hold the OEM stand up, but am not sure that is safe to do. Sure don't want it to deploy while i am going down the road and the retention/return spring seems weak.
    Doug
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    if you got he farley, you got a good sidestand
    get rid of the stocker. you will have to pull the engine mount bolt enough to drop the parts, pull it to the right just enough to let the crap fall out. but you will need to leave/put back the original mount that goes on the bolt/stud/ as it is a spacer.
    yep , I dont know why the factory likes those fac sidestands, they are junk
    love my farley on my 85 R80RT
    Jun 2011
    Thanks, I looked at the fish on Max's web site and think I understand it now.
    I suppose i need to tap the motor mount over with a block of wood and a dead blow hammer enough to get the stand off.
    The bike will for sure go faster without the OEM stand and all that extra weight.
    Registered User Dakar001's Avatar
    Aug 2009
    Boulder, Colorado
    Excellent aftermarket sidestand for R80G/S and ST
    I hated the OEM sidestand on my R80ST. It finally crumbled recently as I was getting off the bike, causing a tip-over and putting me on the ground. I immediately ordered an aftermarket sidestand I really like--check it out at www.flyingtpot.com/sidestands.htm
    I love it and have never looked back. Carl is a great guy to deal with. This sidestand is ultra sturdy and secure, it is mounted in a far better position, plus it has the same lean angle as the OEM.
    1983 R80ST
    2010 R1200GS
    kmkahuna
    Quote Originally Posted by 40427 View Post
    Just stick a small scissor jack under the oil pan with a 2x4 or a block of wood to distribute the load, and take a bit of pressure off the front motor mount while you're gently tapping on the motor mount rod... The front mounting rod will slide right out, the mounting hardware will fall out, and the side stand will just come off..
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    yeah,getting the old side stand off is imperative and simple(pos for years) and installing a way better after market one= way better result/not too difficult.Mine is a Brown's on my 95 R100RT.The stocker is just ridiculous.
    Sometimes,nothing is a real cool hand.
    beemerfield
    Apr 2006
    removing sidestand pin
    I searched the site and found this thread, but I read where the sidestand "pin" will fall out. Mine wiggles, but is stuck. I need to pull it out about 1/16th to slip the spring over the pin in the correct slot. Or, grind down the sidestand, but I don't want to do that. Can I drive the pin out from the outside? Is it just "painted" in place when it came back from powder coat?
    beemerfield
