Results 1 to 8 of 8
Thread: Purchasing GPS, shelf mount for 1200RT
    Greetings
    I'm planning to purchase a GPS with shelf mount for my 08 RT. I also am considering anti theft. Advice on the GPS itself, the mount as well as the anti theft is welcome. I hope to do the hook up myself and welcome advice on wiring also.
    Dale
    Aug 2008
    Kingston, NH
    Dale - moving to Gear as most of your questions are associated to gear for your bike
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Registered User indawin's Avatar
    Jul 2009
    Plantation, Fl
    I'm 100% satisfied with the BMR shelf. Solid as a rock. Wired my Zumo directly to the battery although there are other options.
    Tom
    Plantation, Fl
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    If you're not interested in music/bluetooth, you should at least have a look at Garmin's new Montana line. Aside from a modern touch-screen interface and sunlight readable screen, it incorporates many of the navigational features of the very popular GPSMAP chartplotter series of GPSs and can be. It can also be customized to suit the user's preferences. It has 3GB of internal memory (and you can add a micro SD card for all the storage capacity you'd ever want). It will accept up to 4,000 waypoints, 200 routes, and 200 tracks (each with up to 10,000 track points). You must buy auto-routing maps (like City Navigator). There is also a very useful rugged mount available from Garmin that has bare wire audio/power cable. I bought a Montana 600 a few months ago to replace my 276C (2005 vintage). There's a very lengthy thread in the Layin' Down Tracks forum at ADVRider if you're interested in finding out more. The Montana's not for everyone, but there's no harm in checking it out.
    https://buy.garmin.com/shop/shop.do?pID=75226
    Mark
    2015 R 1200 GS Adventure
    BMR Shelf
    Quote Originally Posted by INDAWIN View Post
    The BMR Impresses. How difficult is it to install? The pics don't reveal how the gussets attach.
    Also does your GPS lock on?
    Registered User tmwilmotte's Avatar
    Dec 2005
    San Antonio Area (TX)
    I have the BMR on my '09 RT and like it. Solid construction and attachment to the bike. My Zumo 550 doesn't bounce around on it. You can get a mounting apparatus that locks the GPS to the BMR shelf, but the one BMR provides would require a thief to use metric Allen wrenches to remove it (assuming you lock your GPS in it's mount). Another plus for the BMR is the layout and the additional shelves you can attach to it for other stuff, like an XM antenna or a radar detector. It was very easy to install. Four attachment points to the bike, as I recall.
    Tom Wilmotte
    2009 R1200RT
    BMWMOA, SABMWRA, IBA
    Jul 2009
    Plantation, Fl
    All of the mounting points use existing screw holes. No drilling required. The standard Zumo mount is not theft proof, although you can buy a locking mount from Wunderlich or others. If I'm going to be away from my bike, I just put the gps in my pocket or lock it in the top case.
    Tom
    Plantation, Fl
    Aug 2007
    Village of Loch Lloyd, MO
    BMR on my 07 R1200RT
    The best most stable shelf made. I have a GPS, Radar Detector EZ Pass, Spot and AM antenna on mine. Every 5000 miles or so, check the screws for tightness and you're good to go.
    Bob Rippy
    IBA #451
    14 R1200RT 07 R1200RT
